Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
How do i change my screen resolution on my f1903
  • 11,361 Answers
You change the resolution at the PC, Right click on the desktop, the display properties will come up, the click on Setting tab to set the resolution. You must make sure that you have correct video card driver installed.
Posted on Apr 27, 2010
Change display properties
To change your screen resolution
  1. Open Screen Resolution by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  2. Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
  3. Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
c976c8e1-2a05-4209-a850-ea7c43422c04_50.jpgScreen Resolution in Control Panel shows the recommended resolution for your monitor.
Aug 27, 2012 | Computers & Internet
Hi, i own compaq presario CQ42 369TU laptop, how do i increase my screen resolution from 1024x768 to 1280x1024 or higher ?
For Windows XP...
1.
Open Display in Control Panel.
2.
On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3.
When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4.
Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
If you cannot set it any higher than 1024x768 and you have already installed the video drivers, that is as high as it can go for your hardware.
May 04, 2011 | Compaq Presario Notebook
My hp f1903 is blurry and I can´t get it to focus. I´ve tried the sharpness on the monitor menu button and have it at the highest level but it does not help.
You should try setting your PC video resolution to the native resolution of this monitor, 1280 x 1024 @60Hz.
If it still bad then you may need to open it up and inspect the inside for bad parts such as capacitors, burnt marks, etc.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 13, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1903 flat screen monitor dimmer with grey lines
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 12, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
What causes a dark screen and a flashing power button for a HP Pavilion F1903 19" flat screen monitor?
Probably find the screen inverter has failed and needs replacing. Can be a fiddly job as you have to dismantle the monitor so take it to your repair shop if you're not familiar with this type of repair.
Apr 28, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Speakers don't Work on HP Pavilion f1903 desktop
Just match the color of the male and female on each end. Plug the audio cable (mini stereo phone plugs) to the PC audio line out (green miniphone jack) to the Powered speaker mini stereo phone audio line input jack (green color jack). You will have to set the volume controls of the speaker control knob and at the PC on screen volume control panel.
Mar 29, 2010 | HP Pavilion F1903 19" LCD Monitor
I do not know how to change the resolution size on the screen
please go to desktop properties. select setting option and now you can change your computer resulation.
Aug 11, 2009 | Computers & Internet
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
