Question about GE Profile JTP18 Electric Single Oven
I have a GE oven it reads true temp ... i dont know the model number. It appears a F1 on the monitor and a beeping sound that wont stop ...
  • gabiarriola Apr 27, 2010
    For now to stop the beeping sound what should I do, just disconnect it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F1 error means circuit board failure so unfortunately to resolve this you have to get the control board replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 27, 2010
  • Rylee Smith
    Rylee Smith Apr 27, 2010
    Yes right or else if it has stop clear button you can press it as well.
How do I fix my GE True temp oven which shows F7 on the display?
https://www.youtube.com/watch?v=Rg7Dp4LBxtA
it seems its the connections ribbons on the control panel is wrong
will give you a clue look down the replys to the video to get more info
some very carefull cleaning is needed inside the front panel rework some connections
i use deoxit 5 and a rag
spray the deoxit to a rag then wipe the connection ribbons
then dowse the plugs with the deoxite
wait a while and re plug then carefully
should cure it
i would add a blob of grease to the sockets once its all running
to avoid further corrossion
hope this helps
Dec 11, 2014 | GE Ovens
HOW DO YOU STOP THE BEEPING
turn the breaker off at the home circuit panel.
Jul 25, 2014 | Thermador SC302T Electric Double Oven
My GE profile kitchen range keeps beeping and flashing an F1 code and I dont know what it is or how to get it to clear and stop beeping
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Feb 17, 2011 | Ovens
My stove keeps beeping and the oven wont come on its reading f1 on the face
This is usually a failure in the control board. The control board can be repaired. Here's a discussion of error codes for the GE models:
fixyourboard.com/techzone/ovens/f1_error/f1_error.html
Sep 19, 2010 | Ovens
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
My older jenn air double wall oven
shooter, F1 is usually the touchpad failure. You can try disconnecting the touchpad ribbon from the control and cleaning the ends with an eraser. See if the F1 stops. Catriver.
May 24, 2007 | Jenn-Air JJW8230D Electric Double Oven
GE Profile JTP18 Electric Single Oven Logo
67 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
