Question about Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
Well pump Sta-Rite MSE-7 now and then won't kick in and buzzes --I replaced the pressure switch-Same thing --Sanded internal points on top of motor same thing pump gets warm contacts in pressure switch don't seem to want to open back up they stay in contact and well just buzzes works good sometimes other times just buzzes what do I do?
  • 990 Answers
In the back of the motor you will find a start capacator. This will be a brown or black cilinder 1" around x 2" long. With the power off unhook the wires to it and note where they go, their will be two or three. You will need to go to a motor shop or a good pool store to get a new one. Then just plug it in and you should be good. If this dosen't help than you may have problems in the windings of the motor and will need to replace it.
The start cap supplys a boost of power to get the motor turning. Once it starts then the cintrifical switch kicks out and opens the points in the back of the motor. When it goes bad then the motor just hums and won't start turning. Be sure to replace with the same cap. The numbers you need will be printed on the side of the cap. Good luck.
Posted on Apr 27, 2010
To purplewg re my Sta-Rite pool pump: I haven't disassembled anything yet, because I'm trying to get an accurate dx before delving. If I take the thing apart, I'll have to replace the seal, and I'd rather...
SOUNDS LIKE BEARINGS .. SEARCH YOUR LOCAL AREA FOR POOL PUMP MOTOR REPAIR GUY, SEE IF THEY OFFER FREE TESTING REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 17, 2010 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Reset button for sta-rite well pump kicks off
That could be a bad wire in the well or the pump motor has a flat spot...or a spot that if the motor stops there it will not start....also could be that the pump bearings are worn and the motor locks up once in a while...
Bottom line the pump will need to be pulled and probably replaced....
http://www.fixya.com/support/r3755320-electric_problems_submersible_pumps
heatman101
Apr 22, 2010 | Plumbing
Loud buzzing sound began on start up
It could be several things but the most likely are: Something is spinning around with the motor shaft. Unplug the motor and "blast" water through the vent holes to clear debris. Let it dry completely before returning to service. Something could be caught in the impeller. Remove the front end and check. Squeals, loud hums, heat and vibration are indications of bad bearings.
Apr 17, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How to prime a sta rite mse 7 deep well pump, when I've filled the 1 inch pipe plug with water and it won't fill.
have to fill the housing complete with fluid. make sure there is no more air in it. also make sure that is not poss. to **** air. also the sucktion side must be full of fluid. watch rotation direction. pump is not able to **** from under 7 meters.
Feb 08, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
May 28, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Open Questions:
See all Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Questions
Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump Logo
1,195 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
