Question about Microwave Ovens
Samsung Micro wave Vitality ce 245g think touch switch not working
The start touch button does not work the other buttons do
I would like to buy a new pad or what ever it takes
I can not find the samsung vitality ce245g listed
help from South Africa
peter@fclb.co.za
    Master:
  • 518 Answers
I can't help with the keypad, but a defective door safety switch can also cause this. They sometimes get out of alignment.
Geno
Posted on Mar 24, 2008
  • craighezlett May 01, 2011
    Thanks for the help......with regards to a "defective door safety switch". How does one go about fixing this? (My keypad has also stopped working - get a C-1 on the display panel)....
Can u plz upload user manual of samsung ce 245g
Posted on Dec 07, 2011
The kitchen timer button does not work on my Kenmore circular wave microwave.
If it has membrane switches, you might have a bad switch. Or, you could have a bad connection between the touch panel and the circuit board. Or the circuit board itself could have a problem.
Jul 25, 2016 | Kenmore Microwave Ovens
My microwave LG MB-2341BR is not functioning as the touch panel not working. The start touch is not working. Do we get touch panel replacement now?
I being an experienced technician all I do is get micro buttons such as used in television set .I carefully apply minimal hot air from a hair dyer to the touch panel in a clean environment then strip the adhesive touch panel to check the wire ring that tress back to the pcb that is just beneath the touch panel. yo have to locate common and the wire responsible for touch, then drill a small hole where the micro button will sit solder to wires on the button then carefully solder them on the board.now make sure the button is on the same level with the surface before you return the adhesive touch panel make sure the button sits well then from beneath apply hot glue please don't use super glue if you don't understand I will send you pictures.
Jun 16, 2016 | LG Microwave Ovens
Hi I am using kenwood microwave since last6 years.but now from last one year it suddenly started make sound while not in working and now it is not heating. Plz guide what to do
Time to throw it away. Microwave ovens can be dangerous if not working correctly. Micro-waves, (The actual waves themselves) can be lethal. Unless you really know what you are doing, do not under any circumstances dismantle the machine and switch it on. The cabinet of the machine is designed as a protective box and should stop random waves escaping and cooking anything else including you own insides. Generally Microwave ovens are uneconomical to repair, for the parts and labour you can buy a new one. Buy the most powerful you can. If you buy anything that is below 1000 Watts make sure it has a turn table. Remember that the more you place in a microwave oven, the longer it takes to cook. If you have a big family and you can afford it, you might like to think about a commercial oven 1600 - 1800 watts, that can cope well with large quantities well and will cook a tin of baked beans in less than a minute.
Rgs. Bob
Feb 21, 2016 | Kenwood Microwave Ovens
My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
Oct 30, 2010 | Emerson Microwave Ovens
Will not start
I have the same problem, diagnosed as bad touch screen panel.
Apr 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave lights up but does not heat or turn table when start button is pushed
Check your door interlock switch. Unplug the device, remove the cover DO NOT TOUCH THE SILVER CAN - POTENTIALLY LETHAL. Locate the small, probably black micro switch. Test it with a volt/ohm meter or other contunity tester. It should read "closed" when the door is closed and "open" when the door is open.
If you are like me, you turn the machine off by opening the door. When you do this, power sparks between the small contacts in the micro switch and eventually burns them up. When this happens, the machine thinks the door is open and will not turn on the magnatron - thus - no heat.
Find a replacement switch at a electronics or appliance parts place. You may have to provide make and model for an exact replacement. If you are handy, you can adapt any regular micro switch.
Let me know if this works for you.
A
Sep 14, 2009 | Microwave Ovens
Kenmore over the range microwave 721.67600 will not cook
One of two thing happened here...
1. most likely...One of the interlock switches has malfunctioned. Micro. will NOT opperate unless ALL switches are working properly for safety
2. possible...the start button on the touch pad has failed in the circuit.
Feb 23, 2009 | Kenmore 62702 Microwave Oven
Sharp carolsel model r1505 on/off buttons broken
Unplug micro wave.
3 screws to remove top vent.
1-screw to remove touch panel from chassis.
tilts foward disconnect wires from board . I labeled for
reassembly .
1-screw holds the touch panel electrics to face plate.
There are 4-6 snap in plastic tabs holding it in place.
you have full access to the cheap plastic hinged buttons.
I hot glued mine once but they broke after 6 months.
I found this site:http://207.234.249.73/mwd/#brands
Good pics and you can see the buttons.
They sell a replacement button for $15 . There is also a
complete service manual for the Sharp 1505 for free download.
Did I mention to unplug the microwave before starting...
Rob H
Dec 17, 2007 | Jenn-Air JMV8208A Microwave Oven
Microwave Ovens Logo
588 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
