Question about Boating
Just bought a used boat, 1966 sportscraft with an evinrude 2 stroke motor, don't know how to test the motor without going into the water. don't know much about boats
    Guru:
  • 60 Answers
Hi. If you just want to run the motor then you can do it in you driveway. Go to a sports store with boating equipment and ask for "Muffs" to run your boat motor out of water. You can see a pictures of outboard motor muffs on google images:
http://www.google.com/images?hl=en&source=imghp&q=muffs+for+outboard&gbv=2&aq=f&aqi=&aql=&oq=&gs_rfai=
Take the muffs and place them over the water intakes located above the propeller (look like vents on each side). Hook a garden hose up the muffs and start water flow. Make sure nothing is near the propeller. Make sure to pump the bulb in the fuel line to the motor until it stiffens. Crank the motor. When the motor starts, you should see water start to flow out of the back of the motor near the cover and out of the center of the propeller with the exhaust. You must keep water flow to the motor using the muffs while it is running or it will burn up.
Posted on Apr 27, 2010
How do i fit a rectifier to a 2013 25hp evinrude 2 stroke???? Rectifier-4wires-2go battery & 2 go AC lighting coil system. Need to identify were to connect my 2 coloured wires from rectifier????
This is what Johnson say;
Technical Contact Information
We Take Your Boating Pleasure Seriously!
Your selling dealer has a special interest in your satisfaction and should be consulted first if you have any concerns about your Johnson power product. Your authorized Evinrude dealer is your primary contact for service, product information, and Evinrude and Johnson® Genuine Parts.
Protect your investment. Please read your owners manual for all operation and maintenance information for your engine. It lists all the adjustments and routine maintenance procedures for your motor, including off-season storage and pre-season service. We encourage you to work with your authorized Evinrude dealer for all the services you require.
If you have a concern with your engine that your dealer is unable to resolve, please have your engine model number and serial number available, and contact us.
Ta
Take a look at these videos though.
https://www.google.ca/search?q=25+hp+evinrude+2+stroke+rectifier&rls=com.microsoft:en-US:IE-ContextMenu&source=lnms&tbm=vid&sa=X&ved=0ahUKEwjVu_XQ2ZnLAhVMQCYKHbMwBnoQ_AUICCgC&biw=1600&bih=729
25 hp evinrude 2 stroke rectifier Google Search
Feb 28, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
I have a 1984 glstron boat wit a 70 hp motor with a 13x15 pitch prop. and have to play with the power trm to get boat to plane out. How do I know if I have the right pitch prop.?
You do not tell us the size of your boat. I sounds as if you have the motor set too high in the transom. Does the motor just rev up and not move the boat or does it lug down and not seem to have enough power? More info, better ideas.
Apr 19, 2013 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
Free download for repair manual for an Evinrude 1987 40HP outboard motor
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster.
I would appreciate any feedback on this problem.
Thax, Don
Apr 27, 2011 | Clymer Marine Maintenance and Repair...
2 or 4 stroke engine
2 stroke.Fuel/oil ratio is 50/ 1.50 parts fuel,1 part oil.They are a very good reliable motor.Hope this helps
Jun 08, 2010 | Bass Pro Boating
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
Boating Logo
209 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
