Question about D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch
Setting up a small network using DSL and a DLink router
I just switched from Buckeye Cable High Speed internet to ATT DSL Internet Access. I have a small network consisting of a Windows 2000 Server, 3 pc's (1-Windows 2000, 1-Vista, 1-Windows XP) I have a DLink DSS-24 port router. How do I get all pc's and server to share internet access using my router. I can only get one pc (Vista) to connect to the internet connected to the Westell modem not through the router. I also need to share the files on the server and none of the pc's can see the shared drive. From what I understand with the DLink there is no configuration needed but need to use PPPOE for my DSL connection.
Any advise on how to get this all to work.
    Scholar:
  • 72 Answers
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Posted on Apr 27, 2010
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
Where is the wireless switch on the dell vostro 200
Unlike notebook computers, most desktops don't come with wireless networking built in. I can't find any mention on Dell's site that the Vostro 200 has wireless capability, so this computer doesn't have a wireless switch. To use your desktop computer on a wireless network, you'll need to install a wireless adapter. USB adapters are very easy to use since you just have to plug them in. They're not expensive and you can easily find them at retail stores and online.
Jun 13, 2011 | Dell Vostro 200 PC Desktop
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I have ATT internet service using a USB device( no DSL or cable wires/lines, just plug in the USB into the port, that's it). I also have a wireless printer that is setup with a DLink router. When I print...
In order for you to print on that particular printer, your computer and the printer need to be on the same network. That is the only way it will work. So, either connect your computer to that Dlink router or connect your printer directly to your computer and browse internet from USB ATT.
Hope this helps.
Aug 11, 2010 | Computers & Internet
Internet connection keeps on dropping
Can't seem to find the manual on it but....
Most DSL/Routers have a connection setting in them with 2 settings.
1) On demand (Connects to internet as needed)
2) Always on (Stays connected to the internet)
Sounds like your DSL/Router is set to option 1
Apr 28, 2010 | Zyxel G-4100 v2 802.11b/g Wireless Access...
I can access internet direct. But no internet Model dir 615
Whilst the router is turned on, try to reset the router by pressing and holding the tiny reset button at the back of our dlink router using a paperclip. Then try again.
Jan 02, 2010 | D-Link Computers & Internet
How do I intall the dlink router if I dont have a cd drive My computer is a dell inspirion and is runs on vista
hello, here is what you need to do: if have a pc connected to high speed modem directly you will unplug the network cable from the back of your pc/laptop and that end will then go in to "WAN" port on the new dlink router.
second, you take another wire and plug one end in your pc/laptop and the other end in one of the 4 lan ports in the back of your new dlink.
restart everything in the following order at 30 seconds duration:- first the cable/DSl modem, then dlink, then your pc/laptop.
once everything is up open up internet browser and test connectivity.
at this point you should have internet up and running but you need to configure you router and wireless etc.
from your browser in address bar type in http://192.168.0.1 and hit enter that will bring you router login prompt : default user name is "admin" and password is left blank and hit enter, you are now in router to configure options as you please.
I would strongly recommend changing your router password administration and if you plan on using wireless, setup SSID, encryption, network key on wireless. NEVER LEAVE IT OPEN.
Hope this helps
let me know if you have any questions
Amar Sondhi
Dec 04, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Two pc connection by dlink switch
connect the router to the switch using any port-it does not matter which port you use. Connect each computer to any port on the switch-it matters not. The router will assign IP address to the computer as they are added.
DONE!!!
Good Luck
Sep 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
I got a laptop from a friend and it came with a dlink routher and card well we ordered att high speed internet and how do i connect to att with my dlink card and router and have a modem that att sent me...
hook your ethernet into the wireless router input (should be labeled with green around it or some other color) then that will activate the router and you should be able to access the internet via wireless
Jul 25, 2009 | Computers & Internet
ATT Yahoo Internet Installer does not recognize the DSL modem
If you can, pls post the exact errror message that you receive and which specific application are you trying to install?
Jan 12, 2009 | 2wire HomePortal 1000HW DSL Modem and...
D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch Logo
536 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
