Question about Ryobi Drills
Ryobi Charger Base, Model # 1400673. Need to know what the 2 resistors are on the PCB. The Bands or the Value would be the best. Big Gray = ???? Small Tan = ????
Slinteriors
  • 8617 Answers
SOURCE: need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Posted on Mar 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: PHILIPS 43PP920217 DPTV305 PROJECTION SET
those are 6.8 ohm 1watt metal film resistors 5% tolerance
Posted on Jul 22, 2008
rowdy45176
  • 2176 Answers
SOURCE: Charger Repair for Ryobi drill 14.4 volt
It has been my experience that when one component of a board goes bad that something else is wrong and even replacing that part still will not work. But you can try contacting Ryobi direct at their website and see if their tech service can get that for you. They are very vague when it comes to some of their products so good luck. Also as a thought if you have a tool repair facility in your area you might contact them and see if they have a junk charger laying around that you can scavenge for parts.
Posted on Dec 31, 2008
SOURCE: was given a Coleman power drill, model CMD8189. The charger is inoperable. The two resisters on the charger internal circuit board have been fried. The resistor codes have been burnt off, so I cannot
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon.
Posted on Jul 05, 2009
SOURCE: Casablanca Vary Quiet PC Board for Series 4000
First, the resistor you are looking for is a 39K ohm +/- 5% tolerance (GOLD tolerance band). Second, FAN MAN still has a couple of new boards in stock, even though his website says he is sold out (I just spoke with him today). VERY nice guy, and VERY reasonable prices. Phone # is (866) 600-FANS (3267). I had the same problem a few years ago (burnt resistor and fried pot) and replaced the resistor and pot. Everything worked again with very little time to fix, and almost no cost. Got the resistor at Radio Shack, but had to order the pot from a Casablanca dealer - read on.......
Now for the pot......
Part #1954150 *IS* a 5K ohm linear taper. I'm looking at the meter and a new pot as I write this. You had me wondering if I misread the meter or something, so I went back and double/triple checked. This pot is installed in my recently rebuilt Vari-Quiet Victorian, and it works fine.
However, I want to tell everyone that I had purchased a replacement pot many years ago from a Casablanca dealer because, as I said above, my old one had fried, along with the resistor (just like your situation). The pot the dealer sent me was a Casablanca part 0001040 (I still have the receipt), and it fit perfectly, so I didn't pay much attention to it. This pot worked for over a decade. But the replacement pot was NOT stamped with the 1954150 part number, and I have long ago thrown out the original - so I don't know at this point what was originally in the fan. BUT, the replacement pot that I put in so many years ago *IS STAMPED* "25K Ohm", and I measured what is left of it and it definitely is a 25K ohm linear taper pot. It worked for over a decade (since 1998).
Now, I have once again rebuilt my fan this summer because the pot again failed (I can't complain, I got almost 11 years out of it). New bearings, new pot, new flywheel, new PCB assembly, new heat sink/transistor, new brass hardware and a a coat of paint/laquer (brass). The new pot was purchased from Plaza Lighting (978) 774-7801, Don Guerette - another VERY nice guy with EXCELLENT prices. However, I got his last pot - sorry. The pot Don sent me is the 1954150/5K Ohm linear taper - the same one that came out of your Vari-Quiet. It also works very well - better than my old 25K Ohm pot because it slows the fan to a full stop at almost a full deflection of the knob (my old 25K ohm slowed the fan to a full stop at partial deflection).
Hence, my conclusion is that the part that belongs in MY fan is the 1954150 pot, and the 25K Ohm pot was the wrong one, even though it worked for many years (no reason it wouldn't, scaling was off, that's all). If you've never done anything with your fan since new (like replace the pot), then the correct pot is the 1954150 since that is what you are taking out of it, and that is definitely a 5K ohm linear taper. You can pick these up almost anywhere. The 25K ohm wa a wire wound. I don't know about the 5K ohm as I'm not about to take mine apart - smiles.
P.S. I was able to acquire a W52 remote control module and install it on my rebuilt Vari-Quiet. It works GREAT (Casablanca sasys you must convert it to a 3-speed before you can use the W52 - LOL)!!!!!
Posted on Oct 08, 2009
Samsung home-theater model no# HT-E330K, power supply resistor RA805 completely burnt can't see the value of the resistor. Pls help with the value of the resistor
This may sound like a lazy answer but without a schematic, its going to be tough. Perhaps you know someone...or maybe there is someone here who has the same unit who wouldn't mind opening it up to get the value. Good luck.
Oct 08, 2013 | Audio Players & Recorders
Charger schematics
WASHINGTON, D.C. - Consumers should stop using this product unless otherwise instructed.
It is illegal to resell or attempt to resell a recalled consumer product.
Recall Summary
Name of Product: Ryobi P113 Dual Chemistry Battery Chargers
Remedy: Replace
Consumer Contact: One World Technologies toll-free at (800) 597-9624 from 8 a.m. to 5 p.m.
ET Monday through Friday or online at www.ryobitools.com and click on Important Safety
Information at the bottom of the page for more information
http://www.ryobitools.com/news_item/Final_CPSC_Approved_Press_Release_11.5.13.pdf
Aug 22, 2012 | Ryobi P113 18 Volt One Charger 140501001
Does anyone know what value the R99 resistor is on the true sub junior
R99 on the Sunfire True Sub Junior is a surface mount resistor (no color bands), and measures 51k ohms. R102 near it is colored gray, red, brown, gold.
Jun 16, 2012 | Sunfire True Sub Jr Subwoofer
I have a B&D Firestorm 18v 1-hour battery charger, model 5100235-09 (240v). When I insert a battery to charge, only the green "battery full" LED lights immediately. But the battery never...
Hi I have same problem with the charger. Solution is to replace the charge with new part number issued from B&D Australia
Number of 90515050-01 until stock runs out , then it is replaced by part number of 90578873 early to mid june 2013.
Hope this helps
Lance from Perth , Western Australia.
Jun 19, 2011 | Black & Decker Drills
Hitachi charger uc18yrl value of resistors: r3, r8, r9
the values that i read:
R3 = 4.7 ohm, savety 1/4 W
R4 = 47 ohm, savety 1/4 W
R8 = 1 k ohm, 1/8 W (seen on working PCB)
R9 = 0.47 ohm, savety 1/2 W
these resistors and Fet: 2SK2996 were defective
May 27, 2011 | Hitachi Garden
Value resistor 719 of chasis serial : qpwbf9254mezz,tv sharp 27" model: 27j-s100 or diagram. thank you for his help
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
Dec 03, 2010 | Sharp 27J-S100 TV
I have a toshiba 61h70. the tv had been shutting down after and few minutes and the red bulb was flashing also. I replaced the IC Chips and it resolved the flashing and shutting down issue. the green and...
You need to look with a meter at the resistors around the chips, they are usually gray in color with bands that denote value--a good guess is one or more were taken out by the chips--in these sets they will look fine---typical is 1.8 ohm (brown, gray, black bands).
At least one is open (bad--no reading across--like checking a fuse) and there will be several with identical color bands on them.
Let me know if I can help.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 16, 2010 | Toshiba 61H70 61" Rear Projection...
What is the value of the large resistor on a KW14-VO board
I overheated my current limiter too, so the colored bands are unreadable. But I measured it at 6.2 ohms. The wattage on this resistor is not really high enough for the job, so they get very hot. I replaced mine with a 10W resistor (too big for board mounting) attached to the board with 22 ga. wires. I clipped a heatsink around the resistor and stuffed it into the empty space at the back of the housing. Hopt this helps.
Apr 15, 2010 | Ryobi Drills
I had projection tv.modle#pt-47wx49.i had convergence problum.i change both big ics.one resistor is blown out. what is the valueof resistor place on R7050,or R7001,or R7059.please help me.
R7050 and R7059 are both 2.2ohm 2watt Resistor R7001 is either 82 or 8.2 ohm if you give me the colors of the bands on that resistor I will let you know for positive what the value of R7001 is
Apr 26, 2008 | Televison & Video
Drills Logo
125 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
