Question about Compaq Presario Notebook
When I move my compaq lap top or type a key too hard
When I move my compaq lap top or type key too hard etc, my screen goes multiple colurs. It has been doing this few weeks and recently started going Blue Screen. I turn off the machine and it reboots, no error on boot other than typical "windows serious error". Is this a motherboard or video card error?
  • 99 Answers
That sounds like a video card error. if you can disassemble the notebook, check for loose connectors, particularly the connector that goes to the screen.
Posted on Apr 27, 2010
I want to know how to restore mr presario compaq sr1720nx back to factory settings
There are multiple instances when you would want to wipe your PC's memory clean and reset it to the factory defaults.
Called "formatting," it is often the last-ditch effort to restore a PC to functionality.
You will also have to format your PC if it gets crippled by viruses.
Although these instructions are for the Compaq Presario, the steps are essentially the same for all Windows based PCs. Be sure that you want to delete everything this process is irreversible.
Back up any data that you want to keep by saving it to removable media, such as external hard drives, flash drives, DVD-R, etc.
Unplug all peripheral devices, except for the keyboard and mouse.
Turn on the computer. As the computer is starting, repeatedly press F1 to initiate the recovery process.
When the BIOS setup screen appears, press the right arrow key to select "Boot".
Press the down arrow key to select "Boot Device Priority" and press "Enter".
Press the down arrow key to select "CD-ROM" and press "+" to move it to the top of the list.
Open the CD-ROM tray, and insert the system recovery disk.
Exit the BIOS setup by pressing "F10". Be sure to select "Save Changes and Exit".
System recovery should initiate. If it does not, and the PC loads Windows, then you have either failed to set the CD-ROM at the top of the boot priority list or you exited the BIOS setup without saving.
Press "R" to begin the recovery process.
When prompted, select "Full System Recovery".
Restart the computer when the process has completed.
Hope this helps.
Nov 21, 2012 | HP Compaq Presario SR1720NX (EL435AA) PC...
My Lap top HDD is not showing up when connected to my Desk top. my siemens lap top hinges broke. I tried working with it and damaged screen. Removed HDD drive and found a free case at home with the USB...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 12, 2011 | Silver Jeans MOBILE DISK HD-234-U2P...
I have a HP Pavillion Lap top and forgot the pass word that goes with my user name
Restart your computer. When your computer is restarting spam the f8 key until it shows you a black screen with multiple options. One of those options will be "Safe Mode". Select this option and it should give you the option to login as administrator when it displays the user select screen. When you select administrator and it lets you in change your account password. Restart your computer again and login with the new password you set.
Mar 17, 2011 | HP Pavilion dv4000 Notebook
My mouse on my compaq lap top is terrible The
hello,
Please reinstall the touch pad drivers once and if then also it is not working the needs to be replaced.
Thanks
Dec 10, 2009 | Compaq Presario Notebook
Monitor goes to sleeep on lap top
Hello, you can try this... Connect your laptop with an desktop monitor throughVGA cable.... then Click on start>> goto control panel>> Double click on Power Option>> Under Power Scheme it should be Poratble /Laptop >> Select Never under System Standbye, Trun off Monitor and Turn off Hard Disk.
Thank you for contacting Fixya support, please rate if that helps!!
Sep 06, 2009 | Relisys RLT1720 17" LCD Monitor
THE SCREEN ON MY LAP TOP IS DANCING
It's probably a virus. Try doing an emergency scan. If you have Nortan AntiVirus it'll be easier. So try doing that and I hope it helps...
Good luck
Aug 06, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
How to clean the LCD screen of lap top ?
you could use a cleaner from Kensington (http://www.kensington.com/html/1081.html)
to clear LCDs and it works great. It comes in a little spray bottle, and I use these neat little 3M 'electronics' microfiber cloths to buff off the spray. Works like a charm.
Jul 09, 2009 | Compaq Computers & Internet
Not able to type ''at the rate, hash, dollar sign etc
Can you please try pressing and holding Shift and then pressing the single quote key ( ' ). Do let us know if that gets the @ sign
May 14, 2009 | HP Compaq nc6000 Notebook
Lap top wont boot up past the windows screen
This generally indicates that a sector in the hard drive has failed, and the hard drive will need to be replaced. With a bad sector the drive reads to the point of the bad sector and past the bad sector, but can't put the info together, so it tries to boot, but can't. Unfortunately, your only option is replacing the hard drive.
Aug 01, 2008 | HP Computers & Internet
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
