Question about Cell Phones
26" Sayno Now has a black dot 2" dia. top of 26" screen. Also three about same size dots on center bottom of screen. plus many tiny blue blue meteor like lines plus three red blue Lazar like lines that go full length of picture. How to fix? Lawrence hoilien ketchum ok. Bought at walmart in feb 2009
    President:
  • 1,469 Answers
when a phone has dotted spot on screen, means that the screen has dirt on it. And when dirt comes on screen, it stays there it can not go off again,.
The only thing to do in this case, is to get a replacement of the screen, because the stain can not go off the screen.it is permanent.
I would advice, you either use it the way it is, or you will have to get a new screen.
NOTE:
Do not try to clean it, it will only get worse.
take care.
Posted on Apr 28, 2010
  • 10,515 Answers
First, you have selected Cell Phone category. But, that's fine. I would be able to assist you.
Unplug the TV for Few Minutes, say 30 minutes, and then Turn it ON.Do you still see the Lines?
If Yes, Use a DVD / PS3 - Do you still see the lines?
I am guessing that the lines are there regardless of which input you select or what Screen Format you Select, Correct?
And this line never moves from one part of the screen to another, it's always in the exact same position, correct?
If Yes, i have a Bad News, this seems to be a Bad Screen panel.
If not, then it is a Faulty Board. Now, in order to get that repaired, you need to Open the TV. Soldering might be Required. If you have the Tools like Multimeter, Soldering Iron, Schematics and have experience to Repair TV, Revert and i would be glad to help you.Unless, a Repairman is Recommended.
Let me know,if you wanted to repair this. ( Do not Forget to mention the Model so that i could also look up the Schematics from my side ).
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 27, 2010
There is a red dot near the center of my Vizio tv screen, what is it?
if just a single tiny dot it is a bad or defective pixel in the front panel-usually there from first time the unit is powered up but from a distance may not be noticed--almost never gets worse or increases in size. Unless set is under warranty do not worry about is as a Panel(entire front screen unit) usually costs more to replace then the entire TV.
Apr 08, 2012 | Televison & Video
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
Hitachi 55vs69a yellow blob in center
you most likely have a bad light engine.
Aug 20, 2009 | Televison & Video
I have black spots on my monitor screen that seem to multiplying.
The black dot will just grow until the rest of the screen fades.
It is pixels dieing in the monitor
Jul 22, 2009 | Computers & Internet
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
There are tiny black dots on my LG Vantage screen
I have the same thing too. My guess is that some of your MEGApixels (tiny squares that create your screen) Are fried.
Mar 30, 2009 | Cell Phones
Blue dots and blue color
my sony is 4yrs also it has blue dots on the left side from top to bottom and a blue blob on rt. bottom corner no longer under warr. please send repair solution.
Jan 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Black spots on my documents Brother HL-1440
Stray dots (on a vertical imaginary line on the page) may not require an expensive drum replacement. In my situation, I simply followed these steps:
(1) Open up the printer, remove the toner-cartridge/drum assembly, and remove the toner cartridge from the drum.
(2) For purposes of reference, place (and center) a sample page of the "offending" output in the bottom of the drum housing, lining up the dots so that the page is turned the way it would have fed through the printer, placing the page generally in front of the shiny green roller surface. Loo, for where any matching black dot or other thing might be sitting on that surface.
(3) Gently roll the green surface's roller with its outside end pegs (without touching the green surface) if and until such a matching dot (or dots) can be found. (Multiple dots might appear along other imaginary verticals on the page, which is to say, additional vertical striping is occurring because there are more instances of "items/dots/garbage" arrayed across the roller on the horizontal, to produce repeat images down the page as the page feeds through the printer.)
(4) Take a Q-tip and very, very, very gently "polish" away the dot(s) you found on the green roller. (I ended up just dabbing the dot I found--which had consistently left a trail of three dots down my pages, in different locations because of the distance the roller traveled relative to the page size--using the absolute least amount moisture to remove it.)
(5) Clean the drum's corona wire by moving the blue plastic slider back and forth, and leave the slider at the far left point.
(6) Reassemble the toner cartridge and the drum and place the assembly back in the printer.
(7) Test.
Worked great for me. Done in around five minutes. No cost, except for the negligible cost of a Q-tip. No time waiting for a new drum to show up, etc.
Oct 17, 2007 | Brother HL 1440 Laser Printer
Blue dots
You have a bad blue LCD in the light engine. Replacement of the light engine is the only fix and it usually will continue to get worse over time
Feb 13, 2007 | LG RU-44SZ51D 44" Rear Projection...
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
