Question about KitchenAid KBMS1454RSS Microwave Oven
Hi I have a Kitchen aid Built in Microwave 24in KBMS1454s and the inlet cover (top center) appears to be warped/melted, how can i find the replacement part or if there was a recall thanks
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: How do you replace the fuse in a microwave oven.
Be sure the oven is unplugged or the breaker is off.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Let us know if we can help further.
Posted on Jun 06, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Posted on Aug 04, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
How do i remove the halogen light in my micowave
I have a similar Kitchen Aid model. The little light inside my unit also went out. I called Kitchen Aid and they scheduled a tech to come out to change it. He said the only way to get to it is to pull the unit out from the wall (it's a built in unit). $150.00 bucks later I had a light for about another year before it burned out too. Needless to say, the heck with it, I don't need the light that bad.
Nov 16, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
Replacement of the Cover Inlet plate inside the microwave, this is part # 8184604. I have the part, I just need to know what to do to replace it. Thanks,
Hi
To locate the inlet cover, look towards the interior side of the microwave next to the microwave display. The inlet is typically located near the back of the microwave, in the middle of the wall.
Unplug your microwave from the electrical outlet and remove any food or containers.
Wipe the inlet cover, typically located on the right side of the microwave in the middle of the wall, with a damp cloth. The cover must be kept clean or it will not protect the microwave.
Dry the inlet cover with a soft towel.
Leave the microwave door open for several hours to air out the inlet cover.
Examine the inlet cover for wear and tear. If the cover has too much damage in the form of scratches or holes, it may need replacement.
Remove the inlet cover, if desired. Insert a putty knife under the plastic nail that holds the inlet cover in place. Pry out the nails and set them aside. Pull out the micro plate in front of the inlet and set it aside. Remove the inlet plate.
Install a new inlet plate. Slide the new inlet cover into its place. Replace the nails back into the side of the microwave by aligning them with the holes of the side.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 20, 2011 | KitchenAid KHMS145KSS Microwave Oven
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Aug 04, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Plastic melted inside oven, dripping from ceiling Kenmore 721
The round peice in top of unit is a cover for the stirrer wich moves waves around for even cooking. The reason for it melting is almost certainly there is not enough paint in cavity and waves are shorting out to metal.CALL the manufacturer and depending on age of unit they may replace it free
Apr 21, 2009 | Microwave Ovens
Small 10 sec fire in microwave
it may be ok , but it should be checked for internal damage
Dec 10, 2008 | Whirlpool MH7140XF Microwave Oven
Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
May 01, 2008 | Microwave Ovens
KitchenAid KBMS1454RSS Microwave Oven Logo
149 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
