Question about Frymaster Dean EH1721 Deep Fryer
ModelGF14SD\r\n My chip truck Frymaster was
ModelGF14SD My chip truck Frymaster was working fine last season and when I took it out of storage I can't seem to light my pilots. They are getting propane, but won"t stay on.
  • 3,083 Answers
This sounds like dried residue in the feed to the pilot light, or inside it. If you're pretty mechanically minded, you can maybe disassemble it enough to blow out the feed lines and pilot assembly with air pressure. OtherwiseYou can lightly tap on sturdier places to try to kind of break the particles loose, and wait for the propant to blow them out. I don't think any condensation could have gotten in it, but if that's the case, it will have to be evacuated. If you can get at the jets with a toothbrush or small brush, you might try to break up any residue in the tip of the jet. Any residual obstruction can cause an intermittent gas feed, so try to clean the valves and feeds as good as you can with a toothbrush and alcohol. Good luck, and I hope this helps.
Posted on Apr 27, 2010
Before storage last year everything was fine with my 2000 Goldwing. When taking the bike out of storage for the season everything seemed ok until my first ride. I discovered that the rear brake pedal has...
Just bleed the brake system. That will take the air out of the system it is a common problem when you let a goldwing sit.
First bleed the front left brake then bleed the rear brake they both work off the brake pedal.
When you are done with that bleed the front right brake with the hand brake lever,
Get a service manual for your wing it explains how to do many services and it will save you money.
Jun 04, 2011 | Honda GL 1500 Gold Wing Motorcycles
1997 Hyundai Elantra - in storage over winter. Can't put into gear when running. Can put into gear when turned off - can then start, clutch depressed, can release clutch and drive but can't shift...
clutch &pressure plate must have got moisture on it & forze together put car in gear & turn car over it should brake free had it hapen to me
May 25, 2011 | 1997 Hyundai Elantra
How many hours do you you season the smoker initially before putting food items in it? do you put water in the pan for the initial smoke? and how many hours will it take to smoke a turkey?
It takes three hours on medium setting to season the smoker. During the last 3/4 hour of seasoning, add 1 cup of wood chips to the wood chip box. Let the chips soak in water for a half hour prior to using them. Once three hours is up, turn off, unplug and let the unit cool off.
Feb 13, 2011 | Masterbuilt Electric 30inch Smokehouse ...
Runs fine until I engage the PTO and am on a slight incline.Starts to spit and sputter and cut off. Checked Plug Gap, Magneto Gap. Worked fine last summer. All I did this time was replace the blades....
check your fuel lines for clogging if it ran fine last year means you have a clogged fuel line somewhere or the carb itself is stopped up disassemble the carb and do a visual inspection also use B12 chemtool carb cleaner use both the spray and the fuel cleaner treatment i know for sure your problem is related to ethanol fuel hope this helps good luck and always run your equipment completely out of fuel for long term storage or between seasons
Apr 07, 2017 | Mtd Garden
Poulan 2150 very hard to pull start..first time this season trying to start...seems like too much compression...pulls nice and easy with spark plug removed..with the spk plug in...very hard to pull..still...
If fuel leaked into the engine over the winter, it could cause very hard-to-pull problems. Remove the plug, ignition off, with the cylinder/head down, pull it through vigorously to see if expels any fuel. Replace last year's fuel with fresh fuel mix. It's a good idea to allow the engine to run out of fuel before storage. Does this engine have a compression release? If so, it may need cleaning to work properly. Hope this helps!
Apr 20, 2010 | Garden
Why does my furnace gas valve keep going bad
Check the ground wire to the gas valve or the wire in the middle of the gas valve that says mv--pv, and that is a ground..
Dec 19, 2009 | Heating & Cooling
Unable to get water clear last season could it be faulty pump
Although the chips inside the pump could decrease the efficiency i doubt that this is why you were unable to get the pool clear. What type of filter do you have, how old is the media inside it, and was the water just cloudy, or did you have algae problems?
Apr 06, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
BSA 3-12 x 50 Rifle Scope
But a new scope. Having the crosshair reseated will cost you more than getting a new BSA scope.
Feb 16, 2018 | Science & Laboratory
Frymaster Dean EH1721 Deep Fryer Logo
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Thomas Perkins
Thomas Perkins
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
