Question about Now Evolution In-Sink-Erator COVER CONTROL Evolution Garbage Disposal Garbage Disposal
I have an in-sinkerator cover control disposal. Its worked fine for 3 months, but tonight its not working. I can feel the magnets on the cover engage, but no power. I tried the red reset button on the bottom. Not sure what next.
  • mkauf00 Apr 27, 2010
    I read somewhere else about draining some warm water with baking powder to clean. I pulled all the gunk out from inside and then did the baking soda thing and it's working again. Thanks all.
  • 299 Answers
In addition to the reset button, look for a button on the outlet that it's plugged into (GFCI). If that's not it also check your circuit breaker panel to see if a breaker has tripped. The next step would be to turn off power to the unit/unplug it and feel around the area where the cover engages for any debris. If all is clear and the unit is not jammed (you'd hear the motor groan if it was) it's time to call in for warranty repair.
Posted on Apr 27, 2010
  • 2,100 Answers
Did you check the breaker? If the breaker is good, the reset button on the bottom is a tough one to get to klik, it has to klik , or it doesn't reset, sometimes you have to hold on to it for a while. Is there something inside the thing jamming it up? Does it hum? The only thing left to do is make sure it has power, and if so, then blame the unit. Hope this helps.
Where is the reset button on sinkerator disposeal
Should be up underneath right in the middle of the motor
Sep 01, 2014 | Electrical Supplies
I have a B&D In sinkerator, 1/3 hsp Model number 1-43 that is leaking from the reset button? What can I do for repair?
Those units have problems with leaks. The reset button is on the bottom of the motor and so the leak is coming though the motor. The housing on those crack pretty easy. I have even see them wear through. They are not expensive and you can easily replace it by yourself.
Jun 30, 2014 | Black and Decker USA Garbage Disposals
Item stuck in garbage disposer
Use vacuum cleaner?
Remove rubber from top and see if you can ge needle nose vice grips onto the object.
Use broomstick and see if you can rotate cutter disk.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Apr 11, 2014 | In-Sink-Erator Evolution Cover Controltm...
There is anail stuck inthe garbage disposal we can see it but it is stuck or bent in the side where the wholes are we cant seemto be able to move it it must be bent or stuck how do we get at it?
Turn power off.
Buy new disposal to have on-hand in event that nail cannot be removed.
Loosen 2 nuts on p-trap to disconnect disposal from tubular drain.
Remove disposal from sink attachment.
Once disposal is removed, there will be easier access to nail.
Use channel locks, vice grips, or any gripping tool to twist or bend nail.
Try to rotate cutter disk with allen wrench on bottom, or wood stick from above.
Use tips on link above to reattach / or replace disposal
Nov 21, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Can the spigot be replaced thet comes off the sinkarator to the drain pipe be replaced? is it as easy as it seems ,simply unscrew it from the sinkerator and screw on a new one.
Yes the drain piece can de replaced real ease. It is just as you said unscrew from the disposal and drain and then put the new on on and rescrew together.
Jan 23, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
We purchased a Silgranit sink and the recommended stopper-strainer (model no. 441098). Our plumber says that this unit is designed to fit through the sink bowl and attach to a waste disposal system (ie....
SILGRANIT II COORDINATED SINK WASTE DISPOSER STOPPER & STRAINER UNIT Fits disposer with 3-3/8" inside diameter only. It should just snap into the insinkerator sink flange.
Jan 17, 2011 | Blanco Sink Waste Strainer / Stopper...
I have a Pro 17 Inksink cover control erator garbage disposal that is not working. Will a Inksinkerator cover control evolution fit good in the same place?
Hi, Yes, that will work...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Sep 19, 2010 | Now Evolution In-Sink-Erator COVER CONTROL...
My garbage disposal does not have an electric on off switch it is turned on and off by inserting the drain stopper and removing it, I have removed the drain stopper but the in sinkerator continues to run.
The switch is bad that the stopper hits to activate the disposal...
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
Aug 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Kenmore Elite 795.7724 - Refrigerator Light Stays on
There is a factory update for this problem. You need a new control board and light parts.
Aug 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Polaroid FLM 2632 HDTV
I hae replaced my polaroid FLM-2632 3 times it is a crappy tv same problem every time do not buy one
Dec 18, 2007 | Polaroid 3211TLXB 32 in. LCD Television
Now Evolution In-Sink-Erator COVER CONTROL Evolution Garbage Disposal Garbage Disposal Logo
595 people viewed this question
Top Now Evolution Home Experts
Donni Steen
Tom Chichester
Are you a Now Evolution Home Expert? Answer questions, earn points and help others
