Question about Carrier 38CKC024 Air Conditioner
I have a Carrier 38CKB048 and it runs without shutting off.
Yesterday my Carrier 38CKB048 Air Conditioner just started to continue to run. Even if I turn the thermostat to off or to heat the outside unit still runs. The only way I can shut it off is to pull the fuse like clip that is on the side of the house by the unit. What could be the poss. solution? Thanks.
    Guru:
  • 415 Answers
99.9% probability that your contactor is stuck/sticking. Replace the contactor.
Posted on Apr 27, 2010
Carrier package unit. 48SS series. Condenser fan continuously runs even when T-stat is off.
The one side of the contacotr in the condenser electrical box is welded closed...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 08, 2010 | Carrier 38CKC036 Air Conditioner
The electricity went off in our neighborhood yesterday. It came back on. I do not run my central air this time of year so the air conditioner is in off position. My fan is on auto but this usually means...
Hello Sounds like runaway blower.The relay in the blower unit is stuck/welded & should be replaced.In the mean time you can turn off the service switch at the unit.If you tap the relay it will shut off (for now) untill the next demand and get stuck again.The relay can be of many types and locations ,trace the wires from the motor to a small box/cube and tap it to free it.
Sep 03, 2010 | Heating & Cooling
Fan motor on Carrier inside runs backwards
Sometimes a motor can start to run backwards... on an indoor fan it is usually because the air inside for some reason started the fan backwards while it was off and then when power is applied it continues to run backwards... once this happens the fan is ruined and it often will not atrt the right way even after the air problem is solved...
You will need to replace the motor and see if you can figure out why there was reversed air flow in your system...
heatman101
Aug 21, 2010 | Carrier 38CKC036 Air Conditioner
Carrier outside unit not starting and is very hot
Either the condenser fan is not working and it has shut down on high pressure... or the compressor is locked up and trying to run and is making the heat...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 13, 2010 | Carrier 38CKC036 Air Conditioner
My AC starts fine. But the compressor will over heat and shut down in higher temperatures (high 80's lower 90's. It has run without issue on some days like yesterday with temps in the mid 80's. The...
Most likey cooling fins are plugged and also my need new compressor or low on refrigerant or refrigerant oil. Could also have plugged intake filters in the intake.
Jun 25, 2010 | Carrier 38CKC036 Air Conditioner
When the thermostat turns off, the condensing unit continues to run. The old contactor was sticking. I could go out and tap on the side of the electrical box beside the compressor, and the contactor...
You most likely have a short. Start by removing the wire on the terminal marked y in the t- stat then see if it shuts down. Look in the air handler for wires touching together. I have also eound wires touching in the wall from the t-stat.
Jun 21, 2010 | Carrier 38CKC042 Air Conditioner
Carrier heat pump (basic model) runs at 0 or below
A basic model heat pump with an air handler with electric strip heat generally will continue to run with a call for heat regardless of the outdoor air temperature unless there was an outdoor thermostat (an accessory) installed. There is still heat in the outdoor even at temperatures of zero and below. Generally, there is a balance point of approx 30-35degF that allows the heat pump to heat your house to 68degF without the need for the electric heaters. Below that, the heat pump can still extract heat from outside and "pump" it into your house; however, it will need help from the electric heaters. In temperatures below the balance point, the heat pump will run non-stop. As the temperature in the house falls approx 1 - 2 degF below the setpoint, the electric heaters will energize. So it is not uncommon for the system to run non-stop with the temperature falling a few degrees below setpoint. The colder the outside temperature, the more often the strip heaters will cycle on/off. If your system is well-maintained and operating at proper performance, it is still cheaper to run your heat pump than it is to run on straight electric heat. If you live in a climate where below zero temperatures are normal during the winter months, you might want to research heat pump options that offer higher COP's and increased performance in colder temperature than the basic contractor's model. Start with initiating communication with a local contractor. You will need to consider initial cost and the pay-back period based on your local energy costs and your specific demands you want your system to meet.
Hope this helps!
Feb 14, 2010 | Carrier 38CKC036 Air Conditioner
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38CKC024 Air Conditioner Logo
301 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
