Question about Kenmore 22642 Top Load Washer
My whirlpool washer has sand in it after the rinse cycle.Is there a filter I need to clean? If so where?
  • 54 Answers
There is no filter Its been a long time since I heard this one. I live in a coal mine area.
we used to have to take the tub out and chip the hardered coal dust from the washers. I comes from the clothes and tennis shoes. No cure i know.
Posted on Apr 27, 2010
My whirlpool frontload washer does not have enough water to wash or rinse properly
1. do you have limescale in your source water, if yes you need to clean your machine with a special product that can be found in the market.
2. pressure sensor is broken
3. inlet filter is dirty you can unscrew the inlet pipe and look for a small filter and clean it.
Mar 24, 2014 | Whirlpool Duet 4.0 cu. ft. Front Load...
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stuck in rinse cycle
Time to clean out your filter..................
Mar 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stopping mid-cycle with no error
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained, unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. F-21 filter blocked.
How abt a nice rating for the free help?
Jan 04, 2009 | Whirlpool GHW9300 Duet Washer
No water for rinse cycle
Take the fill hoses off the machine and clean out the filter inside, right where the hose attached to the machine. Also, check to make sure there are no filter washers in either end of the supply hoses. Sounds like you only have to check the cold water side in this case.
Nov 08, 2008 | Whirlpool Washing Machines
Rinse cycle
most new washers have a cold water only rinse be sure cold water hose is connected to cold side of valve and turned full on ..be sure to ck screen inside cold connection on valve for sand or some other restriction
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR6333LQ0
ch, first thing you want to do is check the hose going to the hot side of the inlet valve. There is a screen on the inlet valve that could be plugged with gunk,grit or sand. Remove the hose and clean it out. The humming you hear is the valve energizing. Something is preventing the water to come through. The rinse is usually cold water so that is why Im suspecting the hot side is plugged. Check this first and if that doesn't fix it, it may be the valve itself...Catriver..post back.
Apr 26, 2007 | Whirlpool LSR6334LQ Top Load Washer
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
Kenmore 22642 Top Load Washer Logo
177 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
