Question about Kenmore 72802 Gas Dryer
Can you show me where the thermal fuse goes for model #11072802101
That would be on the back of the dryer, inserted into the exhaust duct. This is usually within a foot up from the bottom. You will need to remove a couple of sheet screws to remove.
Posted on Apr 27, 2010
Kenmore model 110.80754001 doesn't heat but element is good
The problem could be the dryer thermal fuse. It is usually located on the blower housing. If the dryer overheats, the thermal fuse blows to cut off power to the dryer. If the thermal fuse has blown, then generally the dryer won't start. If your dryer drum rotates, but does not heat, then the problem could be something else.
If it is the thermal fuse, it cannot be reset-if the fuse has blown, it needs to be replaced.
If it is the fuse ... it is also important to figure out WHY it blew ... or else the same problem could show up. Sometimes the thermal fuse blow due to a clogged vent. That should be checked.
Helpful?
Good luck with your troubleshooting
Jan 25, 2018 | Kenmore Dryers
Where is the thermal fuse located on a frigidarie affinty dryer model # faqg7021wl0
Good Afternoon Friend, this is Z. I am happy to assist you!
The thermal fuse on your Frigidaire dryer (FAQG7021WL0) is typically located on the outlet duct. However, I show that this model also has another thermal fuse located on the flame housing. Hope this helps!
Jun 03, 2014 | Frigidaire Dryers
Dryer is 4 years old and will not come on. Just clicks but will not come on. Kind Regards Mr. and Mrs. Priest
Hello Mr& Mrs Priest,
If the clicking that you hear is coming from the control panel,then the problem with your dryer is that the thermal fuse is defective,depending on your exact model these two youtube videos will show you how to disassamble the dryer to replace the thermal fuse.
The thermal fuse usually goes out due to a blockage or restriction in the venting so check that its clear from the dryer all the way to where it exits outside of the house.
http://youtu.be/1obHbwPfw9s
http://youtu.be/aUQQJAxkZ0g
Jul 23, 2011 | Kenmore Dryers
Dryer Samsung model dv316bewxaa a 1 min after begining to run he show on the computer control and setup working
Hello & Welcome to FixYa
HE is a heating error and is displayed due to restricted vent or bad thermal fuse/thermistor. If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | LG 7.3CF ELECDRYER TITN
Have a kenmore 11072802101 gas dryer. it will heat for about 5 min & THEN BLOWS COLD.I replaced thermal fuse.IS IT THE REGULATOR?? OR THE OPPERATING SENSOR.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Dryers
Have a kenmore gas dryer, model # 11072802101, that will not heat at all. have already changed the thermal fuse with no change.
The 'operating' thermostat and the high temp limit thermostat could be bad. There is also a contact on the motor in the element circuit. The two therm. mentioned should read '0' ohms with a meter. (with machine unplugged.)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 09, 2009 | Dryers
I need to put in hi-limit thermal fuse how .show
Hello Friend, This problem will be an easy quick fix for you. All you need is a thermal fuse, your cost under $20. Remove back cover from dryer, look down towards where the air blows out, then just to the left where all the wires are. You will see a little white plastic part with two wires plugged into it, this part is called a thermal fuse. Just unplug these wires and replace the thermal fuse. This should solve your problem. Happy to help, Tim.
Jun 23, 2009 | Kenmore Dryers
I have a whirlpool dryer. Model LER8648LW. Where is located the thermal fuse?
Hi and welcome to FixYA!
That thermal fuse will be located in the blower duct in the back of the machine. Take the back off the machine, look for what will probably light-blue colored wires attached to a white plastic oblong thermal fuse. For your model that part is #
3392519
If this is helpful info please rate me!
Dec 14, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer won't stay on.
tc7059d4.jpg9729365.jpg3403fe5.jpgThe wiring diagram for your dryer is shown in the first image below. A thermal fuse is normally in the circuit to the igniter on many gas dryers. I recommend checking this fuse. On dryer model 11073032102, you can access this fuse by _unplugging the dryer, shutting off the gas supply,_ and removing the bottom front service panel as shown in the second image below. On some Kenmore dryers, you have to remove the back panel to access the thermal fuse. The thermal fuse is located on the blower housing . The third image shows the location and replacement procedure. To test the thermal fuse, remove at least one wire (with the dryer still unplugged) and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms (continuity). If you measure infinite resistance (open), then the thermal fuse is blown and will need to be replaced.NOTE: If the thermal fuse is blown, check the venting for your dryer. Restricted exhaust venting can cause the thermal fuse to blow.
thank You Huuum
Please remember to leave a solved rating before you sign off!
Dec 13, 2008 | Kenmore 63942 Dryer
Kenmore 72802 Gas Dryer Logo
125 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
