Question about Orange Womens Single Speed 26" Deluxe Beach Cruiser
What is the weight limit for a Schwinn point beach 26" cruiser bike
BICYCLES "MURRAY OHIO 26" BEACH CRUISER". (BLUE-METALIC COLOR.) OLD SCHOOL FRAME DESIGN. ( SERIAL # CODE IS " MO1005020" ./ " I AM TRYING TO VERIFY YEAR & MODEL ? " IS POSSIBLY A "MURRAY ( MONTEREY ) 26"...
I don't think there is an answer to your problem because Murray didn't publish a data base of the manufacture date. The best chance is either local bike shop or an internet search under vintage bikes
Oct 19, 2014 | Cycling
My brakes are dragging on my 7 speed Schwinn cruiser?
Possibly to tight, there is a adjustment either at the toop of the brake or at the brake lever, check to see if it can be loosen. Brakes don't just start dragging. Something has to change for this to occur. Brakes do wear, which limits the stopping of the bike. If there is no adjustment, I suggest taking to your local bike shop for assistance
Oct 12, 2014 | Schwinn Sanctuary 26" Womens Cruiser Bike...
My old Schwinn 26" red
Web search "fix shimano internal gear hub" or whatever the bike has.
Aug 09, 2011 | Cyclone Bicycle Pedal Crankset And Arms...
Schwinnn men's 26 " jaguar
The tires will say on the side-wall, it's likely around 45-50psi.
May 05, 2011 | Schwinn Men's 26" Jaguar Cruiser Bike
Need headset size Schwinn Windwood. Want to replace fork.
1 inch threaded. I would suggest you take the bike into a bike shop and have them give you all the specifics related to replacing the fork. You are going to be very limited as too replacements if you use the original headset, Also you need to know the steerer length of both the original (measure your bike) and the fork you will use. This may need to be cut and threads chased, that requires special tools.
Bottom line take the bike into your local shop, have them take a look and make sure the project is going to fit your budget for this bike.
Apr 04, 2011 | Schwinn Windwood 26 Men s Cruiser Bicycle
How to remove a stuck seatpost located inside seat tube? It's a schwinn point beach women's 26 cruiser blue. It's new it just came today because i ordered it from online. And i accidentally put the...
the easiest way is to get a wire coat hanger, straighten it and bent the last 2" back on itself almost like the barb on a fishing hook or an arrow. push this into the seatpost and when it is inside, the end should "spring" back out, and catch on the narrower top of the seatpost allowing you to pull it back out. once out, you can just push the wire through the post to remove it.
hope this helps. if you need any further advice, please feel free to ask
Apr 01, 2011 | Schwinn Cycling
Schwinn women's 26" Windwood front fender doesn't fit correctly.
You have it on backwards.  I had the exact same problem.  Turn the fender around so that the arms that connect to the axel are pointing forward.  They are going to be almost parallel to the ground.  Easy Peasy lemon Squeezy.
Mar 15, 2009 | Schwinn Windwood 26 Women s Cruiser...
Orange Womens Single Speed 26" Deluxe Beach Cruiser Logo
504 people viewed this question
Top Orange Cycling Experts
John Egan
John Egan
Are you an Orange Cycling Expert? Answer questions, earn points and help others
