Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
I have a model 917.299250 5 hp tiller and i have a little plate that is by the choke that came off im not sure what it is called but i need 1 for it
Look on the pullstart housing for the engine model number then go to BriggsandStratton.com and enter it in the search box
Posted on May 05, 2011
  • Iemdub82 May 05, 2011
    You can look at a schematic and find out wut it's called then go to sears website and order it or go to your lOcal small engine shop and order it
Mantis tiller Idles fine, and can even rev... sometimes, but has no power.
check the diaphragm in the carburetor making sure it isn't stiff. depending on how long it has sat, the carburetor may need a cleaning and kit then readjust it to get it to run. Mantis tillers are very temperamental and can be difficult to get to run again even for experienced technicians
Feb 25, 2013 | Mantis 2-Cycle Tiller
How do you adjust the choke on a 1996 mtd lawn tractor
shouldn't need the choke on after running you must have plugged jets inside the carb
Aug 26, 2012 | Mtd Products Yard Machines 158CC Tiller
Tiler only runs at full choke
if its a older briggs engine with the spark plug on the top there is a screw on the carb turn it out a little at a time if not take it off and clean it out
Apr 01, 2012 | Mtd Garden
Will run with full choke on but once i turn choke off it dies
The carb jets are clogged, it will have to be removed and soaked in carb cleaner. Sometimes that will not work either, and the carb will have to be replaced. Reason is, some of the carb passages are as fine as a human hair, so it's hard to get gunk and bad/dried gas deposits out.
You could try running something called Sea Foam (mixed in the gas)from Walmart through the tiller for a while, that MAY help somewhat.
May 23, 2010 | Mantis 2-Cycle Tiller
Troy Built 6.0 HP stored for winter. Fired up and
Most definitely. You aren't getting enough gas, probably because the float valve is gummed up. Drain the gas, put in a little carb cleaner and a little fresh gas. Fire it up. Do that a couple of time if needed, then fill tank with fresh gas. Use a gas stabilizer like Sea Foam to prevent this.
Apr 05, 2010 | Troy-Bilt Pony Garden Tiller
How to start a Troy Bilt Tiller
make sure there is fuel and oil in the engine. There should either be a choke lever/setting or a primer bulb. Push the primer bulb, if there is one, or choke the engine. Make sure it is in neutral, and pull the starter. Should be all there is to it. If there is other info that is causing the machine not to start, please tell model number and what you have done in trying to start.
Jan 24, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have ariens rocket tiller model 901003 i need head gasket for orginal tecuseh engine
part number 28938c i have 20 in stock at lakveviewpower.com free shipping on orders over 100 dollars....call us at 1 972 475 9946 i am assuming u have a 5 hp tec model hh50?
Nov 20, 2009 | Garden
Need help fixing a small troy-built tiller. the carb fell off and I am having trouble putting it back together. I can't get any throttle response when I squeeze throttle.
Make sure that the linkage rod or cable is connected correctly. You should be able to see the throttle plate move with the choke open.
If you need more help, post a comment.
Thanks,
Tim
Jun 28, 2009 | Garden
Craftsman 2.5 hp edger stalls
it sounds like the the carb. either it needs cleaned of the float inside isnt working i would say to just get a new carb. if its possible concidering the age but try to clean the filter first im sure it has one sry but thats all i can think of
Jun 06, 2009 | Craftsman Gas Mini - Tiller/Edger
Mantis tiller dosnt run right
The carburetor needs to be removed, soaked in a cleaner fluid for a couple of hours, reattached and then adjusted.
May 02, 2009 | Mantis Tiller
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
220 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
