Question about Infinity BASSLINK Car Subwoofer
I have constant power and turn on power fuse is good but do not have power light and basslink is not working
    Problem Solver:
  • 10 Answers
I think you dindt but the remote right were it suppose to
Posted on Apr 27, 2010
2 Suggested Answers
SOURCE: Basslink servo light constant on
defect age,short worn its time through had the same thing happen to mine,A SUGGESTION PUT A 25 AMP FUSE,AND PULL IN AND OUT THE GAIN TUG IT,IT SOMETIMES STICKS AND SHORTS YOUR UNIT OUT,GOOD LUCK
Posted on Sep 26, 2007
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
Power light
Hi Bill, I believe the power problem is related to the Remote wire which should be blue or yellow. The remote wire is suppose the turn the Basslink on and off when the radio is turned on and off. The yellow wire is normally used for power antenna. Traditionally the remote wire is blue. You can use a Speaker level adapter and splice in with the L/R rear speaker wires, and the adapter will convert the speaker level to line level. The output of the adapter will go to the Rear speaker input on the basslink., Write back if you need more detail on the adapter.
Oct 07, 2007 | Infinity BASSLINK Car Subwoofer
My cars battery died, and when i turned the car on finally the head unit and my infinity bass link didnt turn on
Check the fuse in your car's fuse panel. If it is burnt then change. If it is still good, check the fuse on the head unit and amp.
Sep 03, 2012 | Infinity BASSLINK Car Subwoofer
Red light comes on and then slowly goes out. No output
For some reason you are not getting constant power to the system. What gauge power/ground are you running? Describe your system to me and we'll see what I can do to help.
Jul 16, 2008 | Infinity BASSLINK Car Subwoofer
2nd Basslink, still no power-on. Please help
this is in response to the post below:
I just bot a basslink t and i wired it up and nothing it just keeps blowing the fues in the unit i got mine on ebay2.gif so i dont know if i can use the warranty dose anybody have an ida for me- britter623
I got a used basslink about a month ago and had the exact same prob kept blowing fuses...found out that the voice coil had blown on the infinity...so I had a brand new dvc polk 10 sittin in the closet, I swapped them out, put the polk in the place of the infinity sub, however, the magnet is much larger, hence, dual voice coil, it would rattle sooo much from the passive radiator against the magnet, also could not turn the gain up at all due to the rattle. I got the bright idea to build a "custom fiberglas enclosure for the polk and incorporate the infinity's parts(amp/control) I finished the box finally last night and hooked it up this morning, no power, no lights, no nothing! s@#%, F&@%! ANyone had a prob w/the amp not having the lights turn on, no power??? Hope that helps about your fuse blowing issue.
Jul 15, 2008 | Infinity BASSLINK Car Subwoofer
Basslink Stoped working after a month ** sound ** red LED
check all your power fuses and insure you havec power where it is supose to be. maybe you have blown a fuse.
Mar 09, 2008 | Infinity BASSLINK Car Subwoofer
Infinity basslink is messed-up
You may have blown the fuse in the AMP. Check it and let me know.
Jan 15, 2008 | Infinity BASSLINK Car Subwoofer
Basslink drops out.
The auto on switch should only be in the on position when the REM wire is NOT connected. Auto on can be flaky. Basslinks respond better to RCA inputs then the high level ones. You might try getting an RCA line converter, they work very well with the Basslink.
Oct 02, 2007 | Infinity BASSLINK Car Subwoofer
So, thanks to the other posters here for getting everyone close the issue that brakes these things! I wanted to pile on, as I repaired mine. See the pics, but yes, you're going to want to get near the power resistors and transistors called out earlier - they COULD be failed, so you will need to do what I did and isolate them to test them (within goo electronic principles). For example, I have a Super Cricket transistor checker that will do the job in-circuit. Many of you will need to remove them to test them for gain with the right meter.
You can see in my pics that the resistors have cooked the caked sealant material, but the resistors themselves were intact and tested right at 3 ohms (correct). So, those weren't bad. However, one power transistor tested bad, so I removed it...to see it test well on the bench? Huh! So, I put it back in, and then notice that the solder pads to both locations were nasty in the original pics I took - they'd CRACKED at the pads! So, cold/cracked solder joints were the culprit here. I reflowed them and the amp powered back up nicely on the bench.
Again, check the pics they show where I had to do the work!
Feb 23, 2007 | Infinity BASSLINK Car Subwoofer
Amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Dec 21, 2006 | Infinity BASSLINK Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
183 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
