Question about E-Machines eMachines Desktop PC
How to recover my system, PLEASE HELP!!!
My E-Machine had Windows XP on it, it became slow, so i installed a OS called Linux, but now i want my Windows back, how can i do that for free??? i dont have a install CD cause my computer was a gift, so i have NO copy of my OS, what do you recommend?
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    Do you have a recovery drive?
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..last time I checked, the MSoft boyz are NOT giving away any software I can recall..
    linux ain't so bad..maybe you'll grow to like it, eh?
  • 4,234 Answers
The machine should have the software key located on it from when the machine was purchased. This "key" is a paper tqg with 4 groups of 5 letter/number combinations. If you can get a copy of the software disc, you can re-install the OS using that key. The discs should be available for minimal cost. It is the key sequence that is important. The software will not install without that key. Please note that you will need to re-register that key with Microsoft once it is installed. This is required to prevent the use of the same key for multiple machines.
Posted on Mar 24, 2008
My laptop which is now 3 yrs old is CONSTANTLY rebooting. It acts as if it is going to fully load Windows XP, but then starts the reboot phase all over again. Is there anything I can do to stop this? I am...
Hi Good day!! try to run your windows in Safemode, to run in safemode, press f8 continuously while booting your pc. Option will appear after pressing f8 choose safemode. your pc will start in safemode. after that do some scanning and then reboot your pc see if your windows will start normally. if not work please relpy to me and i will assist you more thanks!!!
Don't forget to vote Thanks!!!
Oct 28, 2010 | Computers & Internet
How to change Booting Option
Because, Linux is upgrade & so power_full operating system. U already have Win98 & WinXP. If install Linux, previous window not work in same computer, because she (Linux) is ONE. Means, she operate whole computer or system, no more windows chance anytime. Maybe, u install 98 & XP running window time.
Jul 13, 2010 | Mercury P4VM800M7 Motherboard
I have installed dual os(XP and Ubuntu Linux 10) on same drive It is working but my pc became very slow. Now I want to uninstall any or both os but it is showing error. So suggest me How can I?
Hi, try the following sequence.Insert your XP disk and reboot, during bootup press your ESC button or Del on some PCs, you will be in BIOS, from here you can change you primary boot drive, select CD rom, save changes and reboot. Press return when request to boot from CD appears, wait for the sequence to finish installing, select the section of the drive you wish to change, select delete, confirm and then reformat your hard drive. PC will reboot afterwards and start installing XP. Be aware this will remove everything from your hard drive, so back up first. Hope this helps
Jul 10, 2010 | Microsoft Windows XP Home Edition for PC
Have a windows xp home edition,want to install windows xp professional pc wont let me install as 2nd OS,explain please
On the same machine, Windows does not tolerate second OS. Ont the other hand you can install any number of OS' if it is a Linux machine. The trick is to install Windows first and then install Linux etc. The Linux boot manager will tolerate Windows and others and incorporate then with itself. But vice versa is not possible.
May 07, 2010 | Microsoft Windows XP Professional
I have toshiba L305-s5907. i have switch from vista to xp. than i have downloaded drivers from toshiba website but after that my laptop became very very slow. When i was using vista at that time it's RAM...
The reason that XP is only recognizing 3GB of memory is because the operating system is 32bit (X86), what you need for the OS to recognize 4GB is a 64bit (X64) system, does your laptop support 64bit? if it does then get a 64bit install disk, install that and your system will be able to use the full capacity of the 4GB memory installed.
Jun 28, 2009 | Toshiba Satellite L305-S5907 Laptop
Problem installing OS in a newly assembled PC
Try installing first the windows xp.Make two apartments and install the Xp on the one.The other one format it,boot with the linux cd and try to install it to the empty apartment.Be sure that your system supports the linux kernel because some of the CPU brands don't support the linux OS;S.
Good Luck
Jun 23, 2009 | Computers & Internet
Installing Linux
you can use virtual drive to install linux within windows os. you can download virtual drive for free look for virtual box version.
Dec 16, 2008 | Microsoft Windows XP Professional
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
Boot loader problem
I beleive that you are installed windows first and linux second,then dual booting will be configured automatically ,means linux will install the grub (boot loader)and configure it with what all Os u have.If your system is not booting and showing grub menu do one thing ,boot it from a linux cd and reinstall grub.
Oct 31, 2008 | Microsoft Windows XP Home Edition
Where is Linux mbr file
There's nothing like the Linux MBR File. The option to boot to multiple operating systems is controlled by a software called as the "Boot-Loader".
Windows XP and Linux both have their versions of boot-loaders. The Bootloader that Windows XP uses is called the NTLDR, whereas Linux provides many bootloaders (prominent among them being "Grub" and "LILO").
>but Linux is shown in the manage option from the My Computer in Win XP 2.....
That is the control section of NTLDR. So from what I understand you shouldn't have a problem selecting the operating systems.
If you want the Linux bootloader taking control of the boot process, you can always install it.
All you need is a Linux CD and then run the setup for "Grub" or "LILO".
Information about installing Grub or LILO can be found easily on the internet.
Oct 19, 2007 | HP Data Protector Express Software...
E-Machines eMachines Desktop PC Logo
44 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
