Re: Recorded DVD won't play on computer or other players
Yes it might be the format of the recorded dvd, check in which format it is and you can then download the codecs for your PC movie player via google. If you can give me the format I can try and find you a link to the codecs you need if you like.
you can go to divx web page and download a convert tool this should allow you to watch your dvd's and burn them to a more compatable format also try Realpay.com this also recon. divx & you can also burn new disc with this player in mp3, mp4,cd&dvd. modes.P
Does the machine record on to + or - DVDR?
If it does both try each type. Also try high quality discs, some of the cheaper types won't work. Try it on different speeds too.
Depending on your player model, a few things could be going on: 1. The DVD you are recording to is incompatible with your Go Video player. Check your manual for DVD playback compatibility (DVD+R, DVD-R, DVDRW) 2. Your Go Video player has a laser alignment problem. If it plays other DVDs, yours is most likely the first solution.
All dvds recorded on a diffrent player have to be finalised before they will play on a diffrent machine I think that you should find the finalise command in your menu ... hope this helps Reagrds Vortash
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
