Question about Maytag MSD2656G Side by Side Refrigerator
Maytag MSD2656DEW, the frige is running, but not cold on either side. After running for a few minutes it will click, then start clicking again every 90 seconds or so. What is wrong? Is there a part I need to replace?
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerMaytag MSD2656DEW, the frige is running, but not - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 27, 2010
I have a Maytag side by side, MSD2434GEW, about 8 years old, the fridge side appears to be working fine, the freezer side is about the same temp as the fridge and not cold enough to freeze anything. It...
the clicking sound is the compressor trying to start . i belive that you need to reolace the relay start on the compressor . the part that maytag has on ther websight is 12002794 about 34.00 .. mm hope this helps feed back pls ..
Dec 03, 2010 | Maytag MSD2434GE Side by Side Refrigerator
My refrigerator is a Kitchenaid KSRG25FKSS05 and still runs but not cooling. I hear some kind of relay click and then click again after about 10 seconds. Then I don't hear it click again for a few minutes....
refergerant is not causing this problem. when the comp starts up and the bottom fan also starts up and the fan in the freezer comes on / this alll happens whe the cold control said we need more cold . so it sounds like the one that won't come on is the comp . and the clicking noise is the thermal control shutting down. then when cooling tryes to restart. . the kit you need is 8201786 this is called a start device and comes with instructions .. cost about $70.00 . easy to install . mm hope this helped and thanks for the model # .. and for ysing fix ya ..mm feed back pls
Nov 17, 2010 | KitchenAid KSRG25FKSS Side by Side...
Maytag MSD2651HEQ frige not cooling; can hear/feel fan blowing
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Maytag MSD2651 HE Side by Side...
Is my compressor must be replace?
The easiest way for you to find out is to bear the expense of buying the start relay/overload assembly mounted to the pins of the compressor, along with the run capacitor. If this starts it and runs with low amps, like 1-3, you're likely safe. Don't buy food for 24 hours. Sometimes the compressor won't seize again for hours afterward if it has been allowed to cool down before replacing relay.
Aug 22, 2009 | Maytag MSD2454G Side by Side Refrigerator
I have a frige that won't freeze. fridge side won't get cold
This seems to be a common problem with these refrigerators. I had the same problem a while back. Sounds like your defrost board is dead. part number is 12002104. You can find it at searspartsdirect.com
Jun 27, 2009 | Maytag MZD2766GES Side by Side...
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Ice maker and frige
A COMMON FAILURE FOR THE WHIRLPOOL REFRIGERATORS THAT CAUSE NO COOLING IN THE FREEZER IS A BAD RELAY ON THE COMPRESSOR.
LISTEN CLOSELY FOR ABOUT 5 MINUTES TO THE BACK OF THE REFRIGERATOR. IF YOU HEAR A CLICK AND THE COMPRESSOR HUMS AND THEN CLICKS AGAIN AND SHUTS OFF THE COMPRESSOR, THE RELAY IS MOST LIKELY BAD. ABOUT A 40 DOLLAR COMPONENT.
ALSO, CHECK THE FREEZER BACK WALL. IF IT IS FROSTED UP, THERE IS A FAILURE OF THE DEFROST CYCLE. YOU WOULD HAVE TO CHECK THREE COMPONENTS. THE DEFROST CONTROL, HEATER, AND BI-METAL.
Apr 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Coils freezing up on my maytag msd2656dew refrigerator
Replace the thermostat...I had the same problem...I checked the fan, defrost heater and Adaptive Frost control and could not find anything wrong. Replaced the thermostat and the problem went away.
Nov 06, 2007 | Maytag MSD2656G Side by Side Refrigerator
I have a Maytag msd2422gr side-by-side that has gradually stopped cooling 2 or 3 times.  The solution is cheap and easy: Your unit isn't cooling because the space in which the fan is housed is so full of ice you are getting no cold air circulation. The compressor and everything else is functioning, but the cold that is being produced is blocked by ice. All you need to do is to unplug the unit and entirely unload the freezer. Locate a panel with vent slots on the back wall of the freezer compartment that covers the fan. It is held on by about 4 screws. Lift out the panel and behold the glacier of ice covering the coils. You might want to use a hair dryer or space heater to hasten the melting, but I would warn against trying to chip or break it out because you will probably ruin or puncture an important part. Once all the ice is gone, reassemble and plug it back in. As I recall, it takes a few minutes for the compressor to get going again, but be patient because, if there was ice, that was your problem and if it is now gone, that is your solution. It can't help but work. And from now on, you know to be careful not over-load and block those vent slots in the back of your freezer.  If all else fails go here and get great, free help and every part you could possibly need:  http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Mar 27, 2007 | Maytag MSD2656G Side by Side Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
212 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
