I have no heat blowing from my Aquatherm heating system made by First Company?
    Guru:
  • 415 Answers
Use this Installation & Application Manual and refer to page 7 for venting air out of the system. If this does not get the heat going, let us know, and we will dig a little deeper for you. :-)
Posted on Apr 27, 2010
Aquatherm pool heater
make sure it is connected to the solar to get it to work
Jan 06, 2013 | Jandy Digital PoolSpa Control w Actuators...
Amana furnace not blowing hot air
My heating system is running so well because I have Amana furnace.
Nov 09, 2012 | Heating & Cooling
Home AC only blows cool air when set to fan. When placed on Auto/fan it doesn't blow and no heat.
At your thermostat ,
Set switch to heat, turn up temp switch.
Fan should be set to auto. Wait up to 5 mins to be surethat somthing is wrong. If your fan comes on without heat. Check gas valve or if heat pump check main a/c breaker. If elect heat or any of above dosn't work.
Call a service company. If your in Pensacola. Look up Absolute Heating and Air Conditioning.
Oct 30, 2012 | Heating & Cooling
I have two Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner units -- 2 years old. One works fine, but the other does not blow heated air (Heat Mode). It is cold outside, but the good unit is...
your unit may be have possible leak on piping then refrigerant exit or had leakage of refigerant try to locate leak then braze it then recharge a correct amoun of refrigeran. if you use heater try to check heating element if ok by supplying voltage or used ommeter to test continuity.
Feb 03, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
Aquatherm pool heater runs but not heat up
Did you replace the dryer on the unit?
Oct 27, 2009 | Heating & Cooling
RUUD heat pump system does not cool properly.
With a heat pump system there are always going to be a back up heat strip inside the Air Handler.
If you detect a faint humming in the Condenser call your local service company and ask them to come and replace your capacitor in the condenser. The humming is from the contactor engaging but not being able to start the compressor due to not having the required Microfarads to start it.
Let me know if this helps
May 07, 2009 | Heating & Cooling
Honeywell heating system
go to the main power box and find the either breaker or fuse that runs the system and turn it off
Dec 25, 2008 | Honeywell Programmable Thermostat Heater
Have an amana central air duelfuel heat system.when aux heat[gas] heats the house and shuts off the fans still blow for 3 to 5 minutes with the last couple of minutes being cold air which cools the...
Change your heating delay to shut off sooner, you can find this in the installation manual. Also the Thermostat may have delay after heat as well. It is true there could be many variables, but it also sounds like the Heatpump is not charged properly, you will have to have a different tech come out and check that. No need to have the installer mess your system up any further. This solution will only correct the auxilary heat, your heat pump on the other hand will require expert skills.
Dec 05, 2008 | Amana Heating & Cooling
High efficiacy 90 furnane does not blow high heat; yet the fan motor blows but not hot heat.
If the furnace blows heat, just not hot enough, you need to have a furnace company come out and adjust the manifold gas pressure. (This is not something a homeowner can to, it takes special tools)
Jun 18, 2008 | Heating & Cooling
Honeywell thermostat....Home cooling/heating system....Chromotherm III
On heat pumps, the normal setting is simply an air conditioner working in reverse. The EMT or AUX heat is a supplemental heating system using electric heating elements instead of the hermetic (compressor) system. As far as why the regular heat does not work it can be one of many things. low freon charge. reversing valve not functioning. The defrost cycle not working. Take your pick. you may want to call a service man to repair it as the electric (EMT) is not as efficient.
Oct 26, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
876 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
