Question about Arnold Corporation Arnold 21-Inch Universal 3-In-1 Mulching Lawn Mower Blade #490-100-0054
How do you put a ryobi mulching blade on if it for both
How to change from spring blade to solid blade?
unbolt the mulch blade and put a regular blade on it and tighten it,beware,if your deck was made to only mulch,you cannot use regular blades
Apr 01, 2015 | Garden
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
What type mulch kit do I get. One says stamped deck zoom 34
Mulch kits are a waste of money. If you have high lift mulching blades you keep the grass in the deck long enough to do the desired cutting. Open the deflector and block it open with a bungee strap and let the blades spread the grass,so you get no streaking or wind rowing.
CAUTION
Always discharge away from PEOPLE and Buildings and automobiles. I cut an acre here that looks like any golf course with NO MULCHING KIT. MULCHING BLADES ONLY.
Oct 19, 2009 | Garden
How do you change from bag to mulch?
You will need your model number. Go to www.toro.com. Put in your model number.
I know there is a plug you can put in the chute and it will turn it into a mulcher. Without your model number, I was not able to come up with a part number for you.
Good Day.
Oct 16, 2009 | Garden
Mulching blade replacement for Toro GTS 6HP
goto toro website and use model of machine to get blade model and use blade model in google to get prices and then order them
Jul 06, 2009 | Garden
Mowing blade turning the wrong direction
I think you did diagnose the problem. A DC motor will run backwards if the wires are switched around and polarity is reversed. Try switching the wires
Jul 02, 2009 | Garden
Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
Jun 02, 2009 | Garden
What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
May 17, 2009 | Craftsman Garden
Arnold Corporation Arnold 21-Inch Universal 3-In-1 Mulching Lawn Mower Blade #490-100-0054 Logo
66 people viewed this question
Top Arnold Corporation Garden Experts
Dennis Key
Dennis Key
john h
Are you an Arnold Corporation Garden Expert? Answer questions, earn points and help others
