Question about Nikon D90 Digital Camera with 18-105mm lens
I'm trying to chang my shutter speed but bulb
On my camera, whenever I try to change my shutter speed, the word "bulb" pops up in its spot instead. How do I change the speed?
  • kakima May 11, 2010
    The "bulb" doesn't go away when you turn the main command dial while in M or S mode? Normally this is the "slowest" shutter speed setting, leaving the shutter open as long as the shutter release button is pressed.
    What happens when you turn the main command dial while in P mode?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Jun 01, 2010
Changing shutter speed
Like many point&shoot cameras the JZ300 doesn't give you direct control over the shutter speed; you're expected to just point and shoot.
You can indirectly affect the shutter speed by changing scene modes. For example the sports mode will try to use faster shutter speeds while the landscape mode will narrow the aperture for greater depth of field resulting in a slower shutter speed.
Mar 03, 2013 | FUJIFILM FinePix JZ300 Digital Camera
In anything but full automatic, the shutter opens but won't close unless I press the shudder release button again
is sounds like you have the shutter set on bulb.. try changing the shutter speed and see if this helps....
Nov 10, 2012 | Canon Cameras
Sometimes, when I take a picture with my 40d the automatic shutter speeds that display can fluctuate dramatically from 100th of a second to 10th of second in just a split second before I press the shutter,...
your camera is probably set to SPOT exposure instead of AVERAGE exposure,. Which means, your camera is taking readings from a smaller area within the frame instead of using the whole frame to decide exposure. When in spot exposure you can move a hair and the exposure will change dramatically. does this make sense? put your camera back into average metering.
Feb 07, 2011 | Canon EOS 40D Digital Camera
How do I change the shutter speed on a Nikon EM film SLR
The EM doesn't really have a manual shutter speed setting. It does have a Bulb setting for long exposures and a 1/90 second manual for flash, but otherwise the camera automatically sets the shutter speed to go with the currently selected aperture.
Normally you would set the aperture and let the camera set the shutter speed. You can adjust the shutter speed by pressing the exposure compensation button for +2 stops. You can also adjust the exposure by changing the ASA/ISO setting.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_em/nikon_em.htm
Jun 29, 2010 | Nikon EM 35mm SLR Camera
After taking a picture, I get only about a fourth of the image to appear. I tried changing the lens, changing the flash card, but no success
There is either something obstructing the image sensor, or the image sensor if defective. Take off the lens, set the camera to manual mode, select 'bulb' as the shutter speed, then depress and hold the shutter release button. Look inside, what do you see?
Jan 29, 2010 | Canon EOS Rebel 2000 35mm SLR Camera
In manual mode cannot set shutter speed to
The "--" is the equivalent of the bulb setting with the remote control. The first press of the button opens the shutter and starts the exposure. Another press of the button closes the shutter and ends the exposure. This is so you don't have to hold the button down and risk a bird flying through the beam (and to conserve battery power).
Sep 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Shutter speed
When you set the camera to "Full Manual" mode, you should be able to dial in your shutter speeds, for most film cameras, including the N55 30 Seconds is the slowest shutter speed. If your camera features a "Bulb" mode, then the shutter stays open as long as you are holding down the shutter release button.
Apr 12, 2009 | Nikon N55 35mm SLR Camera
F stop settings not responding
Try it on bulb, and open the f and check it is working properly the problem might be the computer inside the camera and there's no replacement spare parts, but yoou canfind another ody and swap the computer.
Oct 01, 2008 | Minolta Maxxum 7000 35mm SLR Camera
NIKON D1X
The shutter is a copal shutter and it does change . Try 125th speed haer the sound and then change to 1/15th . Also you can tell on your histragram inthe camera or the image on your display .
Sep 13, 2008 | Nikon D70s Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
53 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
