Question about HP DeskJet 970cxi InkJet Printer
HP Deskjet 970cxi
The problem is,the 970cxi usb and parrallel-port are nog recognizing by the pc.The cables are ok,the testpage from the printer is also ok.
What can be the problem!!
Can you help my,thanks.
Aart Klinkhamer
Mail:[email protected]
    Genius:
  • 3,587 Answers
Go to control panel, and look at the ports to make certain they are enabled..if not, remove them, then do a scan for hardware changes, and then try it again. I recommend you remove anything plugged into those ports while doing this.
check your computers warranty here 4 FREE
Posted on Mar 24, 2008
SOURCE:
My printer will not print. It says it is queued and it just will not do anything. What can I do to make it print? It does not even say error or anything.
Remove the printer from your PC, delete the printer, restart the machine. Attach the printer, preferably with a USB cable and not the parallel cable. If you already had it using USB, attach it to a different USB port. Reinstall using the Windows driver instead of the driver that came with the printer. Your printer should work after that.
Apr 07, 2010 | HP DeskJet 970cxi InkJet Printer
Were can I get a ethereal cable for my deskjet 970 cxi printer
you can get a cable from any local store example : bestbuy, staples, office depot or a local tech shop.
Jan 26, 2010 | HP DeskJet 970cxi InkJet Printer
I have an IBP PC W. / XP- I purchased a cable with a usb at on one end the printer plugs on the other to plug into the 672 C- added the new driver to update the printer, the computer does not give a ...
  1. Try adding the printer.
  2. Try the HP website for an up-to-date driver. However they may not be making one for that printer. Depends on the age of the printer.
Nov 15, 2009 | HP DeskJet 672c InkJet Printer
How do I connect printer HP 970 to a Laptop HP 8430 ? Which cable ? Thanks for your help.
Hi:
You can connect this printer to your HP laptop using a USB printer cable, It will plug into one of your laptop's USB ports.
Oct 30, 2009 | HP DeskJet 970cxi InkJet Printer
The power light and the paper feed light are both on and the printer does nothing. It's a HP Deskjet 970 Cxi
you going to have to go inside the printer and check for loose cables on the main board. if all cables are ok , i suggest changing the main boar.
Apr 06, 2009 | HP DeskJet 970cxi InkJet Printer
No test print. new one no print after installation.
I have the same problem and thanks for your guidance.
Have a wonderful day.
Sep 21, 2008 | HP D1560 Deskjet Printer InkJet
Deskjet 970cxi will not print
I need to get the driver software Dekjet 970cxi
Can I get driver software.
Nov 22, 2007 | HP DeskJet 970cxi InkJet Printer
HP DeskJet 970cxi InkJet Printer Logo
81 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
