Question about Maytag Atlantis MDE7400AY Electric Dryer
My dryer makes a squealing sound when running. I believe it's the belt on the tensioner pulley, but I have no idea how to get to the darn thing.
    Novelist:
  • 145 Answers
There is no easy way, but its more time consuming really. I'm not familiar with your particular dryer, but you''ll need to remove the top and front casing of your dryer and remove the drum to get to the pulley. Sometimes you can get to it via a compartment on the rear of the dryer as well. Also listen to make sure the squealing isn't coming from the drum bearings on the rear of the drum.
Posted on Apr 27, 2010
Dryer is making a high pitched squealing sound when started,this stops after it runs for about 5-10mins
The belt tension adjustment is allowing too much slack so the belt slips on the motor pulley.
Aug 13, 2016 | Dryers
My whirlpool dryer makes a horribly loud racket. Is the idler pulley or the tension pulley
There is only 1 pulley in most driers, so the idler and the tension pulley are the same part. The idler pulley is on the tension arm, located beneath the drum. A squealing sound is usually associated with the pulley. If it is a slapping or thumping sound it may be the belt, which goes around the drum and the motor shaft. The part numbers are on the parts, or you can order by model. The idler is less than $10.
Apr 03, 2016 | Whirlpool Dryers
Dryer runs but makes loud screeching noise like a fan belt or similar. Does some drive belt need to be replaced?
yes most likely it is the drive belt. pretty easy replacement. go to repairclinic.com or appliancepartspros.com for very good videos to show you how this is done. good luck
Jul 11, 2015 | Dryers
How do I stop dryer from squealing
the squealing noise is most likely a loose drive belt , the drum is powered by a large belt to a motor , the belt and idler pulley are most likeslyin need of replacement
Dec 11, 2014 | Dryers
I have a 2004 Chevy silverado1500 truck, with a chirping now kind of squealing serpentine belt, I changed the belt the idler pulley and belt tensioner it worse for a day after I change something then comes...
If you replaced the belt,tensioner and pulley then you have "glazed" a pulley. There are 2 very easy fixes to try. The first one is to hold a bar of soap on the under (grooved) side of the pulley while the vehicle is idling. Obviously extreme care is required while doing this. If that doesn't get rid of the squealing, spray carburetor or brake cleaner on the under side of the belt while it's idling. That should do it.
Jun 08, 2014 | Cars & Trucks
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
My kenmore dryer is making a squealing noise. It is 5 to 7 years old
This sounds like it could be the tensioner pulley is worn or needs a drop of oil, or the drum rollers need the same. If they are worn too much they will need replaced. If the tensioner pulley is stiff, replace the belt as well.
Jan 03, 2010 | Kenmore 62882 Electric Dryer
Squeal under hood 2000 Pontiac Grand Prix GT (3.8 L)
I would start with a belt. While removing it feel how much tension the tensioner has on it, on the 3800 egnine they have a stiff tensioner(sorry I don't have any specs for how much) After you get the belt off you can look at all of the pulleys and spin them to see if the bind or look for stuff stuck in the grooves on the pulleys.
It sounds to me like the belt is streched. I would not recommend one of those gator back belts, they seem to make more noise sooner than a good v notch belt. But thats just my opinion!
Oct 24, 2009 | 2000 Pontiac Grand Prix
1994 PONTIAC BONNEVILLE TENSIONER BELT PROBLEMS
You need to replace the tensioner assembly, not just the pulley.....
Nov 25, 2008 | 1994 Pontiac Bonneville
Loud noise when dryer runs
Two items on two different dryers can make this noise. One is the belt tensioner pulley and the other is the bearing on a Frigidaire dryer.
Sep 27, 2008 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
225 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
