Question about Tower Aloha Breeze Fan
Cleaning How do you open unit to clean fan?
  • 2 more comments
  • Anonymous Apr 12, 2008
    How do you open the fan to clean it.
  • Chelton Aug 07, 2008
    How to I open the Aloha Tower Fan to Clean it?
    I have taken out all the screws, but still cannot open it up to clean.
    Tucker_tb@yahoo.com
  • Anonymous Aug 31, 2008
    I was successful in cleaning my Aloha Tower fan yesterday. I took out the screws from under the handle and the one at the lower part of the fan that is covered with a screw cover. I then removed the black cylinder by removing two screws from a brass colored plate at the top of the black cylinder and one screw from the bottom of same. The cylinder can then be taken out completely and everything is easier to clean. I put it back together and it is working great.
    how to operate and clean
On the backside of the fan at the botton is a little screw cover. Remove the cover then remove the screw. On the backside top of the fan right under the handle are two screws remove both of them. Gently pry the sides apart, about half way down on both sides are two molded clips, you can use a small flat blade screw driver to help seperate the cover.
Posted on May 14, 2008
  • cannh624 Oct 30, 2010
    Once you get it apart and get the cylinder clean, be sure to blow out around the motor at the bottom - vacuuming alone won't do the trick. That made all the difference in the performance of my fan. And, for what it is worth, my fan had a top clip, that needed to be depressed and 3 "clips" (really just indentations on the inside, not visible on the outside) on each side to release the front from the back.
2 Suggested Answers
SOURCE: Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Posted on Jul 08, 2011
My self cleaning oven completed cleaning but the fan never turned off afterwards
try killing power to the unit at the fuse box
then rreset to see if it comes back on
Oct 28, 2015 | Ovens
HOW TO OPEN THE V188 TO CLEAN
is there a motor or fan that can be heard when pluged in?
Feb 10, 2014 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Unit switches off and displays error code 02-57
According to:
bassfisherman60
From the manual
02-57 Fan lock
This code is output when fan locking (over 30 seconds) is detected.
After the error message is displayed, the power turns off.
Perhaps opening the unit with the power unplugged (of course!) and clearing/cleaning the fan would help. It may be that the fan is just clogged with dust/debris.
Nov 29, 2013 | Televison & Video
Cleaning Fan
Tower fans- Clean your fan by using the brush attachment on your vacuum cleaner to vacuum the intake grills to remove lint and dirt. For safety purposes, never open these units for any reason.
Jun 12, 2013 | Dryers
Cleaning instructions
Dirt is the biggest enemy of your furnace. It can waste fuel and drastically lower efficiency. Dirt affects all three basic components of your furnace, so cleaning is the most important part of regular maintenance. The three parts of the furnace should be cleaned: the filter system, the blower, and the motor.
The furnace filter should be replaced or cleaned at the beginning of the heating season and about once a month during periods of continuous use. To check the filter, take it out and hold it up to the light. If it looks clogged, replace it with a new filter of the same type and size regardless of the length of time it has been used.
Step 4: Clean blower assembly, belts and pulleys to blower, and motor housing. Cleaning blower is critical if furnace has a squirrel-cage fan, because openings in this type of blower often become clogged with dirt. To clean blower, remove panel that covers filter to gain access to blower or panel on front of furnace. This panel may be slip-fit on hooks or held by series of retaining screws. Access to inside of blower is usually gained by sliding out fan unit, which is held on track by screws.
If power cord to fan assembly is not long enough to permit fan unit to slide all the way out, disconnect cord. Mark wire connections first so you'll be able to reassemble unit correctly. With toothbrush, clean each fan blade and spaces between blades. Then, with vacuum cleaner hose, remove all dirt and debris loosened by brushing. Vacuum belts and pulleys. Wipe motor housing clean to prevent heat buildup in motor.
Feb 08, 2013 | Rinnai Toyostove Direct Vent Heater:...
How discharge cleaning blade
Theres a lot of disassembly involved for that. You open the front door....unplug & remove the toner hopper open the right door & remove a metal cover...then take out the developer unit. Thedn back to the front to remove a cooling fan & then screws to take out the drum process unit to access the cleaning assembly and clkeaning blade. If you are not a copier technician....I would not attempt it and call one to get the job done correctly. I assume you must have streaks or lines on the copies which prompted your question.
Jul 31, 2012 | Office Equipment & Supplies
I have a kenmore microhood 63684 turned lites on and can't get them to off,when fan button is pushed fan does not start but when lite button is pushed after fan is energized fan starts real slow and...
What this simply mean is that there has been a problem from the fan either from the wire connection or from the Cole of the fan connected to the fan motor.
There are two ways of over coming this type of problem below are the recommendation to solve the problem
First of all set the oven on self cleaning from the below instruction or make use of your owner manual to operate the elf cleaning
Please after the self cleaning you most allow the oven to cool down to it best before opening
Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
  1. Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
  2. Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
  3. Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
  4. Lock your oven door manually if your model does not lock it automatically when you clean.
  5. Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
  6. Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
  7. Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
SOLUTION 2 IF THE ABOVE RECOMMENDATION DID NOT SOLVE THE PROBLEM
Then you will have to replace the hole of the fan from the oven i.e the fan is need to be service
Hope this help?
Thank you and thank for using fixya.
Nov 26, 2010 | Kenmore 63682 / 63684 / 63689 Microwave...
Kenmore fridge won't run after cleaning fan motor
Check the thermostat and make sure it is sending power to the compressor and fan. If the light comes on when you open the door then you have power to the unit. Make sure you hooked all the wires back up and in the right location
Jan 26, 2008 | Refrigerators
My Laptop Fan is too loud!
If you know how to open up the back cover of the laptop,it is easy to take out the fan unit, have it clean up or replace with a new fan( not very expensive items ).other alternative is to get the service centre to do it,also not very costly.hope it help
Aug 13, 2007 | Sony VAIO GRT260 Notebook
Tower Aloha Breeze Fan Logo
987 people viewed this question
Top Tower Dryers Experts
Jay Finke
Jay Finke
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Tower Dryer Expert? Answer questions, earn points and help others
