Question about Sony (XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10
INSTRUCTION TO INSTALL BULB IN KDF-E42A10. I AM NOT ABLE TO TAKE OUT THE HOUSING TO INSTALL THE BULB IN IT. I NEED STEP TO STEP INSTRUCTION TO SOLVE MY PROBLEM
  • 301 Answers
SOURCE: Sony KDF-E42A10
replace the lamp and you will most likely be good to go.
Posted on Mar 29, 2008
welcomejee
  • 10594 Answers
SOURCE: replaced bulb in a kdf-e42a10 and worked for about 8 hours
3 times red light blinks shows that Lamp Cover is Open. Please put back lamp cover properly.
I would recommend to always replace with Original Sony Lamp and avoid aftermarket or compatible lamps.
Posted on Feb 21, 2009
localwonder
  • 6784 Answers
SOURCE: bulb replacement
Ok, you can buy the bulb separately and it will save you money. I will have to warn that , installing this bare bulb will be tricky and you can not touch this bulb with your bare hands. it will damage it. Other than that, it is possible to purchase the bare bulb alone. i will post a link to your replacement bulb without the housing below.
CLICK HERE FOR YOUR BARE BULB WITHOUT HOUSING.
Please rate and have a great weekend:)
Posted on May 16, 2009
ladywinn
  • 5138 Answers
SOURCE: sony wega kdf-55e200,
If you get just lamp without housing be very carefull you do not put your fringers on Lamp it will leave print and burn into lamp wear plastic gloves to replace this way
Posted on Sep 25, 2009
  • 51 Answers
SOURCE: My screen has dark spots in the upper corners that
Could be Optical Unit (Probably)
Posted on Dec 03, 2009
HI, My Sony KDF-E42A10 TV, power on then goes off blinks red 4 times and have checked the 2 fans that can be seen and are working until it powers off. Any ideas?
there are three fans . the one u cant see is above the lamp housing. u need to pull all the plastic
housing of to access to clean.
Apr 01, 2011 | Sony KDF-E42A10 42 in. LCD Television
CHANGED THE BULB IN KDF E42A10 AND NOW THE COLOR IS ALL OFF, UNIT WAS UNPLUGGED FOR SEVERAL HOUR WHILE WAITING FOR BULB
Step by Step of what you should do: 1) Get into your car 2) Procced to nearest BestBuy store. 3) (This is where its gets tricky) Ask an Employee where the tvs are. 4) Find the televison of your liking and purchase it. Hope this helps
Dec 23, 2010 | Sony KDF-E42A10 42 in. LCD Television
When i turn my tv on,after like half minutes tv turn off by self than starting turning on and off every half minutes....do you think is bulb problem or something als?thx
Symptom shows it is bulb problem that needs to be replaced too solve tv issue.
Existing lamp/ bulb in tv has reached an end of its working life span but still not dead/ broken and causing this problem.
Buy Sony original lamp for good picture and replace it.
Thanks.
Nov 04, 2010 | Sony (XL-2400) Projector Lamp for...
For KDF-E42A10 When picture is black, a bluish fadded spot appears in the center of screen. When picture is white, a yellowish fadded spot appears in the center. Do I just replace the bulb?
no this is a problem with your Optical block your LCD chips have gone bad you need to replace this part to fix this issue the bulb will not solve this kind of issue
Oct 15, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
No Picture on Screen
They might be a problem with the video section(video card)this is where picture is generated and need to be checked there is a possibilty of a chip getting or has a leak .
The bulb gets voltage from this card so pls check it .
GOOD LUCK DUDE.
Nov 24, 2009 | Sony KDF-E42A10 42 in. LCD Television
Replaced bulb in a kdf-e42a10 and worked for about 8 hours
Feb 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Instructions on replacing the bulb not the housing
It's not too bad to replace just the bulb but rather more difficult to find just the bulb on it's own. The guys at lumenarc.co.uk should be able to give you just the bulb. As a start, you might want to have a look at this video:
http://www.youtube.com/watch?v=Xsr3mmLwfNk
Jan 16, 2009 | Sony (XL-2400) Projector Lamp for...
Xl 2400 bulb replacement
Go to
www.dlplampguide.com
and select your set model and watch the video which is a YouTube video. Shows entire bulb replacement start to finish.
Jul 07, 2008 | Sony (XL-2400) Projector Lamp for...
Red and Green Lines in TV
The optics block has failed and it will have to be replaced. Contact Sony for an auth. service center in your area as the optics block in this unit has a 2 year mnfg. warranty.
Feb 16, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony (XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10 Logo
93 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
