Question about Garden
How do i disengage the torque controller on the makita bga452
  • 2,100 Answers
The bga 452 is a 4 1/2 inch angle grinder. I take it you have a cordless drill with clutch> You can disengage it by turning it all the way to drill, it will no longer clutch, the clutch is for driving screws, they won't strip. The lower the number the lower the torque. Hope this helps.
Posted on Apr 27, 2010
I was driving my 95 Corsica suddenly disengaged out of drive no slipping no noises no clicking but a small grind once in a while what could make it just disengage out of drive and now have no gears
it is possible that the problem is not in the transmission but in the torque converter clutch control servo/ solenoid that has disengaged the transmission
could be wiring, TCM, or VSS
run the fault codes or take it to an accredited auto transmission specialist that handles your make of vehicle
Mar 02, 2016 | Cars & Trucks
How do i change the brushes on a 18V Makita BGA452 Grinder
With a little screwdriver you shall first remove the first dustcaps and then you see the brush holder caps which have to be removed with a suitable screwdriver thats by the most machines not hidden but however by this tool
Jun 28, 2015 | Makita Bga452 Lxt 18v Liion Cordless Angle...
Replace brushes
In the middle of the housing set on both sides, there is a cap cover you have to pry off with a small screwdriver to get to the brush caps. Screw the brush caps off and remove the brushes (PN CB-430). If the brushes are stuck, pull on them until they come out. If the brush contacts/wires break off, you'll have to remove the armature and push the brushes through the brush holders. If the brush holders are damaged, replace the end bell, PN638448-2.
Mar 26, 2014 | Makita Angle Grinder BGA452
Makita 6228d has no torque, is the gear box repairable or only can be replaced?
The gearbox (PN 125087-2) is only sold as a unit, no individual parts are available for it. Torque on a drill is usually a function of the power in the battery and the motor's ability to use it. Unless the gearbox is binding enough to make it or the motor very hot when in use your problem may lie in a 'tired' battery or motor issues like brushes.
Mar 02, 2014 | Makita Drills
What is the part number for the makita cordless angle grinder spanner wrench
The Makita part you are looking for is:
782424-9, Lock Nut Wrench 28 for the BGA452
Sep 18, 2012 | Makita Bga452 Lxt 18v Liion Cordless Angle...
Makita 18v angle grinder red light on
Check these sites: https://www.ifixit.com/Wiki/Makita_GA4030K_Troubleshooting or this one: http://www.doityourself.com/stry/troubleshooting-your-malfunctioning-angle-grinder
Jul 01, 2012 | Makita Angle Grinder BGA452
My Makita cordless angle grinder (new, used once) BGA452 wont go, it starts then the overload light comes on and it stops? changed battery, still happens.
Obviously too late for you, but it may help others.
I had the same problem with a new Makita 18v lithium grinder and this worked.
Remove battery, remove brushes. Using good quality cotton buds, dip in Methalated spirit and insert into hole for brush down to armature, slowly rotate head of machine. Change cotton bud and repeat process, then clean the brush heads. Re-assemble and try. Note: Meths will dry completely leaving no residue, unlike turps etc.
Jul 16, 2011 | Makita Bga452 Lxt 18v Liion Cordless Angle...
Can i change the brushes on my cordless grinder?
Hello u2okay, it is a little challenging but, Yes you can. I have done it myself some time ago. I no longer have the information available, but, I went to the manufacturers website and got a list of their authorized parts dealers. That was 8 or 9 months ago and she's still running strong. Well worth the effort. GREAT TOOL!
Good luck my friend!
Jan 16, 2011 | Makita Bga452 Lxt 18v Liion Cordless Angle...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
