Question about Intel Motherboard
System Unit Hello! I had a problem regarding my System Unit. The problem is i can't boot in. System goes on for second then goes off. I check my PSU it's okey and work properly with other computer.. Do you think the problem is with my motherboard as per my findings? Thank's for the help you can make.... Celeron 2.8 Ghz Gigabyte 8s661fxm-775 80 gigs Hdd
  • 53 Answers
U clear the cmos by putting jumper in clear position,then check it once
If the same problem arises the motherboard is the problem.
Pl try it
Regards
Posted on Mar 24, 2008
SOURCE:
My pc restarts after every 2-3 minutes .motherboard is asus P5KPL-AM/PS.please give some solution.
FIRST CHECK ALL ELECTRIC WIRES IF THEY ARE OKEY.
SECOND TRY WITH A OTHER PSU.
Aug 21, 2013 | ASUS P5KPL-AM/PS Motherboard
My fan won t stop running at boot. Acer t160.
JIMMY,CHECK ALL ELECTRICAL WIRING.IF IT LOOKS OKEY YOU CAN HAVE A BAD PSU.
Jul 11, 2013 | Acer Computers & Internet
After a short while, I get the normal 1 beep indicating (from what I've read on the internet) that the POST checks have been passed. Shortly after that, one of two things happen: 1. When booting for...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
the grrr is the sound its not getting enough power
test your PSU power supply unit or replace it if the fan is not working the PSU is faulty
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 27, 2010 | MSI MS-6380E (MS-6380E-010) Motherboard
Hello. Re: HP Pavillion 7965 Where is the power switch located on the system unit?
Hi.
The on off switch is located in the front side, right below the drives.
Most HP PCs do not have PSU power switch at the back.
Regards.
Ginko.
Nov 03, 2010 | HP Pavilion 7965 PC Desktop
Power supply unit gets power as light on the back shows but pc wont turn on. Have tried differnt PSU and pc turned on but have had unit checked and they said the PSU is working fine. Cant fit standard PSU...
Try this to get it at-least back on with your PSU that fits in the case. open up your computer case, locate your power supply. With the AC cord still plugged in , unplugged the connectors to your motherboard from the PSU and wait about 10secs. Then replugged them in. This should power on your PC.
Also, You wanna check around where the PSU connects to the motherboard and make sure there is no damage. No burning,Discoloration anything that could be potential damage.
Hope this works atleast to get the PC booting up.
Jul 28, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
Computer wont boot Evo d510
Choose within this options with regards to your monitor: 1. You could replace your monitor with a new one. 2. Or you could send someone or send it to a technician to repair your monitor.
Boot Up Problem: 1. Try checking the Power Supply Unit (PSU) if it give out 12Voltz. If not you could replace it with new PSU. 2. Check the motherboard if there are some blown out Capacitors. If there is, send it to a technician to replace it. If none, replace your Processor. That is the defective. That causes the boot up problem.
On boot up screen. Of course it will not show a boot up screen because there is a problem on your monitor. And so, there is also a problem on your motherboard (Processor or Capacitor).
Hope this might help. Thanks.
Jul 12, 2010 | Compaq Evo D510 Minitower (Open Box)...
Power LED is On but system doesnot start ?
hello, I have a solution for u i think it may help for u.
your problem is:
When u press the start button... the power LED comes on but there is no POST beep or BIOS screen or boot up. The SMPS fan and Processor fans also dont come on at all. there is a small LED next to the SMPS plug on the motherboard that does light up when the system is connected to a power source.
Part of the system configuration is the kind of PSU you have in your system.
SOLUTION IS
So, what kind of PSU?
Try to borrow a known good PSU. Or better yet, see if you can test your PSU in another working system. If you cannot do that, try to borrow a DMM to measure the voltages. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead.
Jul 01, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Asrock P4i65G Motherboard
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
Newly installed, first boot up PSU problem
If it's a new PSU, then return it for a replacement...Even online distributors will replace faulty units. And since your old PSU works on it, I'd have to say it's the new PSU that's faulty. Did you make sure that it's the right PSU for the CPU that you have? (As there are PSU units for AMD and seperate ones for Intel...Intel just has a additional power cord to connect to the motherboard)
Apr 06, 2007 | RaidMax Aurora RX580 (RX580F) 580-Watt...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
