Panasonic viera wont turn on. TH42PX7A. red led flashes in groups of 8. brand new. Thanks
  • hegemony Mar 24, 2008
    Retried afetr 12 hours off. No different. Will keep you updated. I have heard the 8 flashes might mean needs the SS board replacing. Anyone have the fault codes for this TH42PX7A Viera?
    Thanks.
    Brigadier General:
  • 6,966 Answers
Other than suggesting a full hard reset (unplug from the mains for a couple of hours or overnight), I wouldn't suggest doing anything with it otherwise the warranty may be void.
If your concern has not been corrected after completion of the above procedure, perhaps your best bet would be to seek the services of their authorized service personnel.
Hope this be of initial help/idea. Pls post back how things turned up, if you would waive the warranty and try a DIY or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 24, 2008
  • Louie  Role
    Louie Role Mar 25, 2008
    Hi again hegemony,
    With the indulgence of IB4G2008....
    Search on the net disclosed that 8 blinks indicates fault in Driver SOS 3 SS Board (SS energy recovery circuit).
    Other errors are:
    1 blink STV 5v sense DG Board
    2 blinks 15v SOS D Board
    3 blinks 3.3v SOS D Board
    4 blinks Power SOS P Board
    5 blinks 5v SOS D Board
    6 blinks Driver SOS 1 SU / SD / SC Boards (SC energy recovery circuit)
    7 blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area)
    9 blinks Panel Config. SOS
    10 blinks Sub 5v SOS / Main 3v SOS DG Board DTV 9v SOS / Tuner Power SOS
    11 blinks Fan SOS PB Board
    12 blinks Sound SOS H Board
    13 blinks Communication error DG Board with IC8001 (Pesks Lite 2)
    Though I must say that common problems with your model would be clicking sound and/or delay in video display (which according to some service personnel are normal). Your particular problem indicates a hardware fault and for all intents and purposes better be left to authorized service professionals.
    Should you venture a DIY, please be reminded of safety precautions when dealing with electrical powered devices. It would also require that you be familiar with electronic components and circuitry, use of a DVM, a soldering iron and access to a service manual or at the very least a schematic diagram with voltage readings.
    Cheers.
    Genius:
  • 3,587 Answers
Ok..unplug it for 15 minutes, and then try it again..that will reset the internals
  • Patrick Michaels
    Patrick Michaels Mar 24, 2008
    sure..we can get those to you..what fault code are you seeing? other than the semaphoric light?
SOURCE:
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
My Viera TV: TH-P42ST30z seems to have shut down. When I turn it on the pilot light initially flashes green then starts a sequence of 7 red flashes, a gap, 7 more red flashes and this continues indefi
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 09, 2014 | Panasonic Televison & Video
12 blinks on th-p42x20m
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Apr 13, 2014 | Panasonic Viera TH-50PZ85U Plasma TV
Panasonic viera th-p42g10a plasma tv has flashing red led light
The number of flashes is indicating a specific error. If you let me know how many times the light is blinking I will let you know whats most likliy causeing the issue. Reply to this same post for assistance.
Nov 09, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Panasonic Viera plasma and everytime i turn it on it lasts for about 10secs then turns off. The red light blinks 8 times. The model number is th42px7a. Should i fix it or buy a new one?
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, If otherwise, power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem......
Jul 01, 2011 | Panasonic Viera TH-50PZ85U Plasma TV
Power light comes on and flashes green but no picture then flashes red on my sony viera model TH42PX7A
in this case there is parts is partly opened or shorted. just consult it to the sony service center
Jun 19, 2010 | Televison & Video
Tv wont turn on, red led flashes 10 times
If this is NOT projection, then the power supply is burnt out. If it is projection, then either high voltage transformer, flyback, or power supply is at fault
Nov 08, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic 42 inch Viera Pixel Distortion
We have the TH-42PX70A which has the same problem. It comes and goes..It is only 2yrs old, warranty has run out. The moving red pixels are on the black and the cyan pixels are on the white. It will go away for months and then return for a few days. It is not an antenna problem as the signal is still there.I am taking it in today for the tech to look at, but I turned it on this morning and it is fine. So I wont be able to show him.. (took pics though).Everyone says they are the "best" and all that, but every now and then you get a lemon. If it turns out to be too costly, I will buy a new one and it wont be a Panasonic.
Oct 17, 2009 | Panasonic TH37PX60 37 in. Plasma...
Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
Oct 30, 2007 | Sony KLV-S23A10 23 in. LCD HDTV
Televison & Video Logo
855 people viewed this question
Top Televison & Video Experts
Ekse
