Question about Maytag 30" Built-In Single Electric Wall Oven - Black
The temperature control button that also controls the hi/lo for broil, setting the clock, etc. on my Maytag Cwe900 broke off. Can we replace this ourselves or do we need to contact a service tech?
  • Maytag Master
  • 3,051 Answers
Hello there:
Yes these parts can be replaced by the customer but if this has a warranty that is covering the oven i would go ahead and use it cause there is always a possibility that the part may not be put in exactly the right way or correctly and this could cause further problems and like i was saying earlier about the warranty a lot of times there are updated parts that can be installed at no charge to the customer so all you have to do is to call the place of business that you purchased the appliance from and give them the make and model number of the appliance and describe to them what the problem is and ask about the warranty ok
Hope this is very helpful for you best regards Michael
Posted on Apr 27, 2010
On a whirlpool double oven, what does F2 error mean
F1 - Control Board Failure - Replace control board (clock). F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ... F3 - Open Oven Temperature Sensor Replace oven temperature sensor ( ). F4 - Shorted Oven Temperature Sensor ( - Replace oven temperature sensor
Nov 23, 2016 | Whirlpool Ovens
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
Cant clear code or use oven after small power surge - stove top still works. GE web site does not have a F81 code they have an F8 and F1 which both say problem with keypad and electronic control needs to...
You didn't post model, but with a surge you probably looking at replacing the ERC. Does the manual say to unplug to reset, or check again on reset the control.
Some have this for reset, can't hurt to try.
  • Press the BAKEand BROIL HI/LO pads at the same time for 3-5 seconds until the display shows SF.
  • Press the COOKTIME and BROIL HI/LO button (on some models press Broil only, refer to your use and care manual). The display should show C. Press the button again until F shows in the display.
  • Press START to complete the change.
  • If this clears control, do it again to reset to Fahrenheit.
    This way actually resets for a error also besides temp.
    You can check the price of a control here,
    http://www.repairclinic.com/
    And you can google search for more places to shop prices.
    Mar 30, 2013 | Ovens
    Ge profile f2 error while broiling in upper oven
    F2
    During
    BAKE Control senses oven
    temperature above 615F-630F If actual over temperature condition occurred: Look for
    welded relay contacts on bake or broil relays. If this happens, replace oven
    control (also called clock or ERC).
    If no over temperature condition
    occurred
    : Look for a high resistance connection or any other cause of high
    resistance in the oven temperature sensor circuit. Check sensor, sensor harness
    and sensor harness connection at sensor and oven control. Replace sensor if
    found defective.
    Remember: Oven control (ERC) measures resistance
    of sensor circuit , not actual oven temperature. F2
    During
    CLEAN Control senses oven temperature above
    915F-930F If actual over temperature condition
    occurred
    : Look for welded relay contacts. If this happens, replace oven
    occurred
    found defective. Check door lock switches.
    (ERC) measures resistance of sensor circuit , not actual oven
    temperature.
    Jan 24, 2011 | GE Profile JTP56 Electric Double Oven
    Oven doesn't seem to be heating to proper temperature. Both elements are hot to the touch when first turned on. Broiling element is red hot when on broil. Baking takes longer than what is reccomended on...
    Hi
    The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1100 then it is the sensor that is bad & if the rating is around 1100 then it is the board that is bad & should be replaced. Hope this helps...
    Daniel
    Jan 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
    Kenmore Electric Double Oven Mod 9114832592992 got F2 code in middle of selfclean what do I need to fix?
    Hi, i found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
    F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
    OR....
    F2 Oven temperature sensor shorted Replace oven temperature sensor
    OR
    F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
    Oct 26, 2010 | Kenmore Ovens
    The oven wont heat up.
    Hi.
    Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
    The temperature probe is located inside the oven cavity.
    On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
    When the probe fails, it will affect both baking and broiling function.
    The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
    If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
    If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
    Regards.
    Mar 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
    HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
    If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
    If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
    Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
    Aug 04, 2009 | GE Ovens
    Can't turn off my Kenmore 47833
    check to see if the connections are good on the back of the control board and if they are good then you need to replace the control board (clock) assembly let me know how you make out
    Sep 01, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
    Maytag 30" Built-In Single Electric Wall Oven - Black Logo
    79 people viewed this question
    Top Maytag Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Mack Baxter
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
