Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
Replaced the color wheel, now everything is blue
  • 175 Answers
It is the polarized filter the blue one gets worn out and you get a blue haze over screen common problem with most dlps and rear pros. cant buy them anymore so you can either buy a new engine which is expensive or find one broken for parts
Posted on Apr 27, 2010
Whats the primary color of blue?
Please first study on color wheel to get the thorough knowledge. Then furthermore, you can read some books and play some DVDs for art lessons to get some more sound knowledge to be equipped with yourself. Check out: Art instruction books DVDs and everything you need to learn to create any...
Feb 02, 2015 | Crafts & Hobbies
My samsung 61in. Dlp screen flashes green/blue pic is viewable but everything is the two colors, also screen will flash icon check fan #1
You have 2 problems. Problem 1 either you main board or light engine is bad and needs to be replaced. Problem 2 is exactly what your TV says. Fan#1 isn't functioning properly so a heat sencor is being actiated to shut down your set. Make sure all the fans are free of debree and spinning. If one is not spinning, make sure it has voltage going to it. This will let you know if you have a bad fan, or a bad board.
Jun 05, 2012 | Samsung 61" Slim-Depth LED DLP HDTV
I bought a used Toshiba 62mx195 with what u was told was only a bad bulb... great, bought and replaced bulb, now overtime I turn it on I have one color variance... either everything is blue or been or...
Make sure every input does that too. If not, you probably have a bad hook up from the device or the T.V. If not, it's probably your color wheel or DMB board.
Jun 23, 2011 | Toshiba Televison & Video
Color Wheel
I'm pretty sure if the color wheel spins with no vibration that it's not the colorwheel. I would have to say that your cable is bad. If it has been bent repeatedly near the connection that the wires could be breaking down. Try a brand new cable.
May 06, 2010 | Panasonic PT-D4000U Projector
After color wheel replacement colors are wrong
you need to index the color wheel after repalcing it so its spinning at the correct speed
Apr 30, 2009 | Televison & Video
Samsung dlp model hlp5067wx
the color wheel has to be replaced. (Technican Job) this device is inside the light engine,
Jan 06, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Color wheel
could be a jumper on the DMD board that must be removed, look for a small sticker that points to the jumper, or it could be a setting in the factory mode, mute-182-power will get you in there, check the settings for the color wheel
Jul 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsug rear projection tv, everything looks green
Dust accumulation in color wheel, light tunnel, chip area can cause green tint.
It is very delicate area, light tunnel and chip can be easily damaged. Remove light engine assembly and color wheel. Blow dust out. Re-assemble. If the gasket around the color wheel housing is not replaced in the right position, or the housing screws not tightened correctly dust will contaminate the color wheel/light tunnel area.
Call someone that has done it a few times. If near Calgary, call me.
easyab
Jul 14, 2008 | Samsung HCM4216W 42" Rear Projection...
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp color issue
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Mar 28, 2008 | Samsung HL-P6163W 61" TV
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
143 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
