Question about GE Spacemaker JVM1640SJ Microwave Oven
How to Remove a GE spacemaker Microwave from under cabinet mounting?
  • 999 Answers
If installed correctly there will be 2 bolts oing down through the upper cabinet and when you take the grill across the top off there should be a lever to pull to release a latch. Recommend there be 2 persons there as it is heavy and has to be lifted off the lip of the wall plate once it is tilted forward after the above steps are done. Good luck...Eric
Posted on Apr 27, 2010
Can you provide under cabinet mounting instructions for GE Microwave part WX4-A19?
To mount it under a cabinet, you have to have the under cabinet install kit; you'll find that here: Under Cabinet Mounting Kit WX4 A019 GE Appliances the kit does include instructions. You can't mount it without the kit.
Dec 12, 2015 | GE Microwave Ovens
How to remove ge spacemaker xl
You want to take the microwave off the wall, is that correct. 1st unplug the microwave--plug should be in the cabinet over the microwave. Next--in the same cabinet you should see 2 or 3 phillips head screws with big heads going through the bottom of the cabinet into the microwave top. Have someone hold up on the microwave while you remove the screws. They are about 3 inches long. Once the screws are out, the microwave should tilt forward and downward at the front. The back of the MW sits on 4 tabs on the wall mount plate so to get it off completely you have to lift the back up slightly off the tabs about 1 inch. Feed the power cord down through the cabinet and you are done.
Feb 28, 2015 | GE Profile Spacemaker XL 1800 36"...
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Remove mounted GE Spacemaker Microwave JVM140K
There should be 2-3 screws thru the floor of the cabinet above the m/w that secure it in the front. Once those are removed the m/w will slide straight out on rails mounted to the wall plate.
Dec 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
What size bolts do i need in order to mount it under the cabinet. the bolt that comes from the cabinet into the micro
mcdevito75 here, Best Bet bring the mounting bracket and bolts recieved with the unit to your local hardware store. they will give you the correct bolts need to mount undera cabinet.
Jun 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Removal
There are 3 mounting screws that anchor the microwave to the cabinet above it and a bracket on the wall behind it. Once you remove the mounting screws from the top, pull the oven straight out from the front and it will slide off the wall bracket.
Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
913 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
