Question about Ambico 67" TRIPOD
One of my legs of my ambico tripod has fallen apart. I think i have all the pieces but how do i the leg back together?
SOURCE: Velbon VMATE-607/F Tripod - Broken Leg Lock
duct tape
Posted on Feb 27, 2008
Agent Allan
  • 480 Answers
SOURCE: With what can I lubricate the legs onmy aluminum Mafrotto tripod?
Dear Winnieg,
I would avoid using a lubricant on your tripod legs, because you run the risk of the legs not tightening down anymore. I would try cleaning the tripod thoroughly first, because most of the time this is caused by dirt. If that dosen't work I would try rubbing on a small amount of candle wax onto the legs, and then wipe the legs down with a clothe.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Apr 22, 2008
  • 373 Answers
SOURCE: Legs lose grip and get shorter! How do i tighten them??? Help!
I am not sure what kind you have but mine there is grips around the legs you grap and turn and the other one I have has a handle you flip un or down I hope this works out
Posted on Feb 12, 2009
morgan747
  • 9 Answers
SOURCE: Leg clamp tightening adjustment on a 055 tripod
There should be a nut on the other side of the housing of the tightening lever that you can tighten. Turn the lever to unlock the leg then start with 1/8 th turns of the nut to tighten, then turn the lever to lock the leg. Do this until you get the desired locking.
Posted on Mar 20, 2009
SOURCE: The lower leg clamp on my SLIK U212 deluxe is cracked.
Per another post on here i located a website which sells Slik parts -
http://kenkooutlet.com
- the part was cheap but the shipping was too high in my case. Good luck.
Posted on Jul 24, 2009
I need one large and one small leg clamp for my Ambico Tripod.
Parts are not available for that tripod. Unless you find the exact same tripod (Ambico model numbers are often wrong and reference different models) then you cannot get parts.
Aug 25, 2013 | Photography
I need instruction manual for manfrotto 058b tripod
There is a red slider under the main casting that will release the legs all together.
Apr 13, 2013 | Manfrotto 058b Triatt Camera Tripod Black
The lower leg would not lock and comes off.
The grey part might be a shim that fits up into the leg lock in order for it to fit more securely. Ambico is no longer in business, and parts are not available so you might have to replace the tripod if you can't fix it yourself. You find tripods here: www.itripod.com
Feb 22, 2013 | Ambico Photography
How to take apart manfrotto monopod 682b? I need to take it apart to fit in suitcase and then put back together. It is about 3" too long to fit on airplane.
You can loosen the top screw on the top leg lock. Just enough so you can pull the bottom legs out of the main tube. Ths shoud shorten it up a bit. You wil need a small spintight or wrench.
May 22, 2010 | Manfrotto 682B MONOPOD 0563025 3D
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
Want specifications for titan ii ii-950
Call Ritz Camera at 877-999-RITZ (7489). They "might" be able to assist you. Ritz's generic lenses are Quantaray made by Sigma. I don't know who makes the tripod. They are able to provide documentation for you, but I don't know if they will. Ritz has an online help form that you can fill out on their web site also
The little 'hooks' on the bottom of the legs 'snap' into each other to secure the legs together. Each leg has a 'hook snap' which clicks into place with the other legs. It is merely a way to secure the legs from flopping open. I bought the same tripod, a good solid piece of equipment. No instructions but its easy enough to figure out. Hope this helps.
Feb 26, 2009 | Quantaray QSX-DigiPro 8500 Tripod
Ambico v-0552 parts needed
I've seen these on eBay, sometimes pretty cheap!
Mar 24, 2008 | AmbiCom V0552 Tripod
Libec THM20
The leg is slightly off the track, which is a curved piece which fits along the tripod support rail. If you're not careful when collapsing the legs you'll force the leg to go off-track like this.
Sep 07, 2007 | Libec ST30 Tripod
One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
May 26, 2007 | Velbon Ultra MAXi Tripod
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Ambico 67" TRIPOD Logo
60 people viewed this question
Top Ambico Photography Experts
Tony
Are you an Ambico Photography Expert? Answer questions, earn points and help others
