Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
The fuel tank is cracked at the top by the cap.What site can I go
Have a Troy bilt tb425cs the fuel tank is cracked at top by the gas cap.What site can I go to buy the fuel tank and part #?Any help appreciated. Thanks
    Scholar:
  • 47 Answers
Search MTD's parts warehouse online. THey ,manufactured these units for the Troy Bilt label.
Here, I will do one better, here is the parts page for your exact model number. Have fun!
MTD parts locator for Troy Bilt Products:
Posted on May 09, 2010
  • 54 Answers
Can't help with the tank, but your better auto parts stores do sell an epoxy that is designed to seal plastic fuel cells.
Posted on Apr 28, 2010
When I compress the trigger to get higher speed, it dies on me.
Fuel jet may be plugged Not uncomon on small carbs. I had same problem replaced carb $19 from troy Built Problem solved
Jul 02, 2014 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Tb425cs
c1438ee1-896f-4a41-8cac-2b1351074190.gif Hi keith
I hope this is what your looking for
Bud
Apr 23, 2013 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
How do i fix my flooded TB32 EC troy bilt weed eater?
be sure fuel filter is on the primary fuel line in the tank.check primer bulb and fuel lines.also check fuel tank cap.vented cap may be stopped up
Sep 10, 2012 | M T D Southwest Inc Troy-Bilt TB32EC...
My tb425cs leaks gas when it is running. It drips from the bottom of the gas tank.
Be sure to not overfill the tank. Just load it with gas up to the bottom of the neck and be positive you're not cross-threading the cap when twisting it on. If it only leaks when operating, see if there is fuel bubbling out through the vent(s) in the top of the cap or out from under it. Also wipe the tank clean and dry to be positive it is not leaking from a seam or crack in tank or around fuel lines. If leaking from cap, might have to replace as they do have an internal rubber seal that could have gotten dry or cracked. If it's from the tank seams or fuel lines replacement may be neccessary of either one or both.
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Starts and then shut off Troy bilt edger
clean out carb and run gas cleaner throught the tank
Dec 27, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My troy-bilt TB425CS gas string trimmer gas lines have gone away. In replacing those lines how far into the tank do they go?
far enough so that you can reach through filler cap and pull the line out to attatch fuel filter.
then you can pull it back in and let it rest on the bottom of the tank
Aug 14, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Rough idel and no throttle on a Troy -bilt BT25ET
It sounds like you have done everything but replaced the fuel filter. Which is usually located in the fuel tank. And clean the muffler. You will probably find some oil and carbine build up.
good luck
Aug 07, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
203 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
