Question about HP Pavilion dv2000t Notebook
LED light is Orange and wireless is not working
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
If you google your problem you would find that it's a common issue with HP DV series laptops. Please read up on this and hope your laptop is within extended warranty. If not you may soon need motherboard replacing as this is only beginning. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277 Good luck!
Posted on Apr 27, 2010
I have a WRT54GC Router, it was working good, but started to work bad. When I plug the power cable, all LED light and the power LED turns orange.
Have you tried hitting the reset button with a paperclip? That will reset the router to it's default factory settings after that follow the directions for first time setup
May 18, 2011 | Linksys WRT54GC Wireless Router
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
NO Power,but when you press power button the wireless led became orange,but stll no power,desplay,and the procesor fan not working,.,
this could be a problem with your power cable. If the power button and wireless LED go orange, means battery is not charged. try to borrow another power cable (if possible) otherwise you will have to bring it to a service center.
Oct 20, 2010 | Computers & Internet
No wi-fi signal transmitted
There is a reset button in the back of your router, which will reset it to all default settings. Try this to get the router to work.
Also is it hard wired into another computer? Check it out that way. make sure the router is working.
good luck
Apr 13, 2010 | Linksys WRT54G2 Wireless Router
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
Printer will not work
Waste ink full reset
These are the instructions which worked for me on my Canon pixma ip470:
Feb 02, 2010 | Canon Office Equipment & Supplies
My Acer netbook will only keep an internet connect when plugged in.
This netbook has a little orange led that blinks to let you know that the wireless is turned on. Then you know you can connect to wireless networks. Take a look at the photo here:
www.geekzone.co.nz/images/news/AcerAspireOne.jpg
To the right of the touchpad, at the front edge of the palmrest (closest to you) you will see a small silvery stripe. This is where the wireless led is.
First, look and see that the little orange led is blinking. If not, slide the little switch right beside it to turn on the wireless (you should see 'wireless lan enabled' in large green print) If you can't seem to get the orange led to blink by doing this, check device manager and check that the wireless card is enabled. If it has a red X on it, right-click on it and left click enable.
If the led is blinking, but you still can't connect to wireless, see if you can connect to another wireless access point other than your own.
Let me know if this helps or not :)
Aug 17, 2009 | Acer AOA150-1690 Aspire Notebook
The device is not working. When I conect the power, power led is off and wireless led is fixed green. Sometimes, when I reset the router, the power led turns orange, and the otrers ligths off.
This is a sign of a bad router already, so if its still under warranty you can go have this unit replace from Linksys , since this is already a hardware problem...
Aug 14, 2009 | Linksys WRT54GC Wireless Router
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
HP Pavilion dv2000t Notebook Logo
245 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
