Question about Amana ARSE665BS Side by Side Refrigerator
DOESNT DEFROST AND THE FRIDGE SIDE NOT COLD - Amana ARSE665BS Side by Side Refrigerator
    Scholar:
  • 126 Answers
YOU CAN MANUALLY DEFROST THIS AND GET IT GOING UNTIL YOU GET IT REPAIRED. UNPLUG REFRIGERATOR AND LEAVE FREEZER DOOR OPEN FOR 12 HOURS OR MORE. OR UNPLUG REFRIGERATOR, TAKE THE LOWER PANEL OFF INSIDE FREEZER AND DEFROST WITH A HAIR DRYER. THIS SHOULD TAKE ABOUT 45 MINUTES. THE MOST COMMON REPAIR IS THE DEFROST THERMOSTAT. YOU PROBABLY HAVE A BAD ADAPTIVE DEFROST BOARD.
Posted on Apr 27, 2010
22yooper
  • 828 Answers
SOURCE: kenmore sideby side fridge
You have a defrost system problem. Defrost is controlled by a timer which energizes the heater circuit. The heater circuit has a radiant or cal rod type heater which melts the frost from the coil. When the coil reaches a temperature where all ice would be gone a termination switch opens and shuts of the heater. The timer will continue to run until defrost time expires (18-22 minutes).
If you can locate the timer there is a clutch head screw to advance the timer to the defrost position. Turn the screw clockwise SLOWLY until you hear one audible click. The heaters should come on and defrost take place. If the unit restarts after the 18-22 minute period the timer is good, if it does not restart advance the screw to a second audible click and it will restart.
If you had to turn the timer the to second click to get it started cooling replace the timer.
If the unit restarted after the 18-22 minutes and defrost did not happen your problem is in the heater circuit. This would be an open heater or bad defrost terminator switch. To access the heater and defrost terminator the back panel in the freezer section must be removed. With an Ohm meter you can check the heater to see if it is good.
Posted on Jul 02, 2008
  • 111 Answers
SOURCE: GE side by side fridge TFX22JR not staying cold
You need to unplug the unit and check continuity with a meter across the defrost heater/s. If they are open, that's your problem. The defrost termination thermostat HAS to be below 20 degrees (varies model to model) to close. If at room temp it will read open. Doubtful it is your defrost timer.
Posted on Dec 16, 2008
SOURCE: freezer workss but fridge dont
Check for a frost buildup on the interior back wall of the freezer. If you find this, a problem exists in the defrost circuit (heater, terminator or control).
Also verify that the evaporator (freezer) fan is functioning.
A failed damper control can cause this condition as well.
Proper product temps are 0 to 10 in the freezer and 36 to 42 in the fresh food compartment.
Posted on Apr 29, 2009
jmgldsmth
  • 1889 Answers
SOURCE: Freezer very cold fridge warm.
the freezer circulates air through the refrigerator by using a fan every 24 hours the defrost timer comes on the compressor goes off and, the machine defrosts if your mullion defrost heaters are getting hot
and, staying hot you have miss-wired your defrost timer
Posted on May 25, 2009
rockitman187
  • 2559 Answers
SOURCE: Freezer wont defrost and fridge not cold
Better solution is to replace the defrost element,defrost timer,or defrost thermostat,one of these are not working and when replaced will fix the problem.
Posted on Aug 01, 2009
Refrigerator doesnt get cold
you have a defrost issue, could be a timer, a board, a heater, or a bimetal. i suggest you call for service. 200 to 350 depending
Jan 03, 2012 | Kenmore Side by Side Refrigerator
Freezer works good but food side doesnt get cold and fan in freezer runs all the time
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 27, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Why the fridge side doesnt cool, the freezer side is working. I had the thermistor replaced. It is RS257 BARB
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Oct 29, 2010 | Samsung Refrigerators
Freezer works fridge doesnt?
most likely defrost problem . most refrigerators getting their cold air from the freezer, so if your frezzer frost up, no air gets to fridge side, u have to remove the frezzer panel and inspect the evaporator coil, if frosty, u have bad defrost system, which part is bad? depends on the brand and model.
Oct 31, 2009 | Dometic RM2852 Refrigerator
Whirlpool side by side fridge not cooling
Yes, only part that gets could is in the Freezer. If block by ice (usually) this will not allow the cold air to go into the ref., if so, defrost problem. Check amount of ice on coils in back of Freezer. Should only be a thin frosting.
May 02, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Open Questions:
Amana ARSE665BS Side by Side Refrigerator Logo
96 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
