Most modern gas ovens have a device called a Glow Ignitor to light the burner. If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights: Do you see a bright glow near the Broiler burner? (Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like- But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
