Question about Coleman Sport 1850 Generator
Generator will not run unless i use starting fluid.
Will not fire when i pull start it but when I shoot it with starting fluid it starts but doesnt stay running. Gas is getting to the carberator. What might the problem be.
  • 5,603 Answers
You have a fuel problem. Fuel filter clogged? Carbuerator may need cleaning. Is there a hidden fuel shutoff valve? I have left mine closed... it is embarassing but it happens. I assume you put the choke on initially...
Posted on Apr 27, 2010
A Coleman Powermate 6250 with a Briggs and Stratton engine new won't crack. Got gas to crab and motor full of oil. Spray starting fluid in it it until it's gone. Why wouldn't it start? ??
If its new, SOME generators will not start unless at least 3/4 full of gas. Spark plugs secured all the way in? Gas switch on? Pull the choke? NO MORE starting fluid, Bad Louie, BAD! some of the suggestions i posted above may help :) but, no more starting fluid.
Jun 29, 2016 | Coleman Electrical Supplies
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Ef2600 yamaha generator will run fine for a day Go to start it the next day it won't start
If the fuel tank is below the carb, check for a check valve in the fuel line not seating. You can verify by shooting a bit of starting fluid in the breather. If it starts and then hesitates a bit and then runs, it means that the engine speed was adequate to suck fuel back up into the line to the carb.
Jan 10, 2015 | Yamaha Electrical Supplies
Generator wont start up unless i spray starter fluid into it
This sounds like a dirty carbureator. Just bad enough that it won't start cold.
Mar 29, 2014 | Electrical Supplies
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
Aug 25, 2012 | Honda Electrical Supplies
Generator is brand new. Was run once. Started on first pull. Hasn't been run for two years. Can't get started. Tried spraying a little starting fluid on air filter, nothing. Help?
The odds are the fuel went bad or water has gotten into the tank during the two years of inactivity. Drain the fuel tank and fill with fresh fuel. Also, you may want to change the spark plug (just in case since it's inexpensive) and the oil. Once these are accomplished it should fire right up. Hope this helps!
Feb 28, 2011 | Garden
Our onan generator ran out of gas. we refueled but the generator will not start. i gave it a shoot of starting fluid, the generator fired and run for a second, then died. could it be a cogged fuel filter?...
No, not the filter, you will need to try to prime the carb better then with starting fluid, pour some gasoline down the carb, you may have to do this a few times, but everything will fire back up again once you get the air out of the system
May 25, 2010 | Watts Onan Portable Generator - 4000 ,...
Trys to fire now and then . It has a weak spark.
start with a daignostic test, simplely remove the airfilter, tiurn the switch on,spray a one second spray of starting fluid into the carb, pull the engine, if it fires then you have identified the problem, bad gas and dirty carb. If it does not fire on starting fluid then you have either a compression problem like a stuck valve or an ignition problem, calling for a new ignition module. Good luck, white back if I can help more?Jim
Dec 19, 2009 | Coleman Powermate Powermate 5000W...
I cannot start my power washer - what could the problem be?
It could be no fire or no fuel it just might be a sparkplug take the spark plug out and touch it against the head or block it had to touch metal pull the rope it should fire if it doesnt fire change plug and try again if it fires then put plug back into the head if it still doesnt start spray some starting fluid in the carburator and try it again that will bypass the carburator that will tell you the problem if its fire or gas
Nov 07, 2009 | Garden
I have a coleman powermate 5700 generator with a 10HP Yamaha MZ300 engine. It set most of the winter and it will not crank. I have verified that fuel is getting to the bowl. I have cleaned the...
Bascially you need to completely remove the old, stale fuel to start with. (you can use the old fuel it in your lawnmower mixed 50:50 with fresh fuel to use it up).
Then once you've drained the fuel tank, you'll have to clean out the carb with a Fuel Injector and Carb cleaner. Really spray the carb till it's soaked, since you've got a schellaced fuel system.
Make sure you remove the air cleaner so you can get the spray into the carb. Also, with the spark plug removed, and the power switch turned "off", so the generator won't try to start during this process. You can also slowly crank the engine with the pull starter, to help work the cleaner through the system.
Then let the unit set for about 10-15 minutes, so the cleaner can evaporate, etc. and then you can reinstall the spark plug.
Now add about 1/2 gallon of fresh fuel and you can try starting the generator. You might have to use some starting fluid to get it started, by carefully spraying it into the carb in very small bursts to keep the motor running
Once it's running smooth, you should always use fresh gas and make sure to add a quality fuel stabilizer, such as Sta-bil, to the gas you use in the generator, as it will keep the fuel system protected for up to 2 years.
I also always turn off the fuel shut-off on my generator to use up the gas in the line before storing it. Also, you should get the generator out at least every 3 months and run it for 15-20 minutes to keep everything working and lubricated, so it will work when you need it.
Just be sure to always add more Sta-bil to your fuel and turn off the fuel shut off and let it run out, before storing.
I've done this with my generators and they're now over 14 years old and always start on the first pull and run like tops!
If you can't get the unit running smoothly, you may have to take it to a small engine service shop for them to do a "tune-up" for you.
Hope you find this Very Helpful and best regards!
Sep 19, 2009 | Electrical Supplies
Coleman Sport 1850 Generator Logo
640 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
