Question about Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S
We have a noritz tankless water heater that we installed & it stayed on all evening, provided hot water etc. Decided to move the display & turned off. Now when we go to turn it on, it will flash FF on the display for about 5 seconds & then turn off.
  • Chris Sellers
    Chris Sellers Jul 12, 2010
    you need to disconnect the power whenever connecting or disconnecting the remote. Simply unplug the heater, wait 20 seconds, and the code should be gone when you power it back up.
    Scholar:
  • 73 Answers
Check the wiring connections for your remote. The FF is related to communication problems with the remote. You should also reset the unit by disconnecting electricity, waiting 20 seconds, and then reconnecting electricity to the heater.
Posted on Aug 01, 2010
How to descale a noritz tankless water heater
1) Copy following links for general descaling resources for Tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
2) Add a comment with what you discover
Jan 04, 2013 | Noritz 6.3 Gallon Residential Tankless...
Noritz NR98-DVC tankless water heater won't give hot water thru a single valve fixture. Gives us all the hot water we want on a double handled fixture. Any suggestions on what to do?
Replace single-handled faucet cartridge, and see if hot flows to that faucet again.
http://waterheatertimer.org/Crossover.html
Exposing tankless to hard water causes reduced efficiency within a few months, and can cause Total failure of parts within two years.
Do not expose tankless to more than 11 grains hard water.
Here is research pdf conducted by water softener industry comparing tankless andf tank-type:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
To solve problem long-long term, install tank-type gas water heater from local box store for $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 12, 2012 | Noritz NR98-DVC-NG 100W Freeze Tankless...
Noritz tankless gas water heater. Hot water pressure is low. Unit does not "click" on when hot water is opened. No hot water.
The unit is plugged up with mineral buildup from the water going through it... it will need to be cleaned internally....this is done by running an acid solution through it to clean out the mineral buildup...
Then it will work again...
heatman101
Feb 02, 2011 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
WHAT SIZE HOLE IN JET ON HOT WATER HEATER TO CHANGE FROM NATURAL GAS TO LP GAS
That doesnt work with these units they are manufactured gas specific. The manifold plate would need to be changed as well as notification to Noritz to have a new serial # issued. PC board reprogram required, etc. Buy a natural gas or LP model.
Apr 27, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
After water to house was shut off, my Noritz tankless water heater is on but won't produce hot water. On the unit, the light indicating that the burner is on stays off now.
you probably had debris get into the filter or flow sensor when the water was turned back on. I'd recommend checking the filter first and if that doesn't work, call Noritz Tech support to help you with the flow sensor.
the filter is a black plug located on the cold water line (labeled cold on the bottom of the unit). It points torwards the left.
Apr 14, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Noritz Tankless error code 16
The trick with these hot water heaters is to keep the filter screen clean and flush the system with CLR periodically. Code 11 is ignition error. Is your gas valve turned on?
Oct 17, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz tankless water heater/dishwasher not hot enough to clean
You are doing everything you can. Your dishwasher probably isn't drawing enough hot water to activate the unit so opening the faucet and flowing more water will activate the unit. Just try to adjust the flow from the faucet to a point it, plus the draw from the dishwasher, will activate the unit. This will come with trial and error as I am sure you have already experienced. Also, open the dishwasher when it does get filled and check the water temperature. You might have the unit set at a low discharge temperature. Do you have a touchpad to control the water temperature adjustment?
Feb 17, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S Logo
186 people viewed this question
Top Noritz Water Heaters Experts
gizmonix
Level 1 Expert
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
