Question about Breville BTA820XL 2-Slice Toaster
One side stuck down, lights flashing - Breville BTA820XL 2-Slice Toaster
Why is the power light flashing on my HP printer?
Check if has no small piece of paper stuck
Check USB cables (both sides) .Remove heads, first Black then color.
Disconnect USB. Still continues flasshing?
If flashing comtinues, try to uninstall - reinstall the printer.
If still "flashing" without any apparent reason take it to repair.
May 23, 2015 | HP PhotoSmart Office Equipment & Supplies
Flash stuck
It sounds like the flash up switch is stuck closed so that even though the flash is down the camera thinks it is up.
Slide a business card under the left side (the rewind side if you are old enough to remember film cameras) of the flash when it is down to free the latch and remove the two screws on the bottom of the flash so you can pop off the cover. You can then see the switch on the release side of the flash at the pivot. The flash up switch contact that looks like a crooked finger should be above the post. Gently reposition it and check the action of the switch by manually freeing the latch.
Be very careful. There may be over 300 volts across the two wires that are soldered to the flash tube. If you touch them you will get a nasty shock.
May 07, 2013 | Nikon D3100 Digital Camera
Light keeps flashing in spa
Sounds like control panel failure or the keypad is locked/stuck.
Try hold temperature UP & DOWN together for 6 seconds.
or if you have a Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
As your lights are flashing the button might be stuck in the down position.
Jul 18, 2012 | Balboa Instruments Pool & Spa
Paper jam. Paper is caught on left side then forced to the right side. This happens a couple of times, then stops???
check paper path , you may have something stuck on paper path . try to fiend it, used a flash light if you need to, put printer up side down, shaek it, good look : )
Sep 28, 2009 | Epson Stylus CX5000 InkJet Photo Printer
How do i reset my service light on my v70 1997 please
  • Press and hold odometer reset button
  • Turn ignition switch to Run
  • After SRL flashes, release odometer reset button
  • Confirm by turning your Volvo off, then on again
  • Jul 12, 2009 | 1998 Volvo V70
    Lock on light flashing
    I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
    Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
    The icon with the exclamation in the middle is flashing, and
    Put your mouse pointer on the Icon, the with your middle finger only, press down on the right side of the mouse. This will bring up a menu on the Icon.
    Dec 27, 2008 | HP LaserJet 1320 Printer
    Flashing symbols
    Is there another part to the error code besides the 8 like a letter in front of it?
    Jul 18, 2008 | Sharp AR-M205 Copier
    Breville BTA820XL 2-Slice Toaster Logo
    Top Breville Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Jerry Greenberg
    Jerry Greenberg
    bengsoon Neo
    Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
