Mitsubishi CS-35313 While watching tv, the screen went green for 2 or 3 seconds then turned itself off, I tryed it a couple of time in the next 2 days and the same happened. On the 3rd day it was back to normal....Any ideas what to expect next? Thank you very much for any help Phil
  • phil30360 Mar 24, 2008
    Thank you Computes, I think your right...
    Phil
  • 74 Answers
If it is not a cold solder on the CRT board at the end of the tube (inside)...... then the CRT (tube) is bad. The CRT costs more than the set new.
Posted on Mar 24, 2008
Picture one day, no picture the next
try resting the device again for few hours n then try
Aug 19, 2008 | Mitsubishi VS-60601 60" Rear Projection...
About 2 weeks ago my check engine light came turned on so i drove home and told my dad about it but when we turned the car on it did not flash. But the the next 2 days it stayed on and the next morning...
Any time you get any check light, you should
be at a repair in a couple of days, or at least
check for codes. Still need it diagnosed and
repaired in a week
Otherwise you waste gas,polute the air or could
cause some damage,as you don't know what the issue
is that set the light
The fact the check light went out, doesn't mean
the problem went away.
Don't clear any codes you find,their needed to diagnose
the system faults
Apr 05, 2011 | 2006 Mitsubishi Eclipse
WS-55511 shut itself down while watching TV and won't come back on again. I tried unplugging and reconnecting, it goes through the reset (green light blinking). The convergence went bad and the chip was...
After you turn on and green power light comes on and then goes out:
Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it 4 more times.
Let me know what error code and I will tell you what it means. If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
