Question about Brother MFC-3220C Plain Paper Inkjet Fax
Fax receiving problems
Hi, i have i brother MFC-3220C and i don´t get my faxes. Every time i´m receiving a fax, there is a text on the display: "Please open cover"
Can you help me, what to do?
[email protected]
Thanks!
Beatrix
  • Anonymous May 11, 2010
    The printer has an error of some sort. The only way to truly know is to get into maintenance mode. The bad thing about that is you can mess the machine up worse if you are not careful and put in the wrong codes. Would you like to try it?
    New Friend:
  • 89 Answers
Check whether there is any paper stuck inside.
Posted on Jun 24, 2010
SOURCE:
How do you connect to your computer
You can buy this cable or use the one provided by Brother
Belkin PRO USB 6' Cable USB cable, 4 pin USB Type A (M) - 4 pin USB Type B (M), 6 ft
Belkin Cable 4 pin USB type A (M) , 4 Pin USB type B (M)
Detail in this link
http://www.superwarehouse.com/Brother_MFC-3220C_5-in-1_Color_Multi-Function_Center/MFC3220C/p/332703
Apr 22, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
How can I fax a Paper?
Load the original face down
dial the fax number
press START
Mar 17, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Error 41 MFC 3220C
WELCOME TO THE ERROR 41 DELIMA. YOU WILL NEED A NEW PRINT HEAD, MAY BE U CAN BUY ONE FROM A BROTHER DDEALER AND INSTALL IT GOOD LUCK
Jan 27, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Print head for brother mfc-3220c
how do you remove the ink cartridge from mfc-3220c when the lever is stucki
May 18, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Receiving faxes
The memory may be corrupted which is affecting the it receiving incoming faxes - to clear the memory: 1. Press the Menu/Set and Fax Resolution keys in this order. 2. Press the 0 key. 3. Press keys 91 (Parameter Initialise will appear in the display)
Sep 07, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Printer problem
It needs a new printhead. I have heard you can find them on ebay. A service center would charge you too much to be feasable. Not because they want to rip you off but because they have to make a profit like any other business.
Sep 01, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Unit Waste Lots of Ink
I have had the same problem, so I decided to use the fax only for sending faces. I took the ink out of the machine so
Aug 12, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC-3220C Plain Paper Inkjet Fax Logo
96 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
