Question about Hotpoint RGB745 Gas Kitchen Range
What does 'F2' mean on the display of my Hotpoint Gas Range
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: WP Touchpad does not work.
The error code of F2 and E1 on your gas range is indicating a keypad failure or an Electronic Range Control (ERC) board failure. The ribbon connector on the keypad could be damaged or shorted. One of the buttons could be stuck or shorted on the keypad. There is a good possibility of a failed (ERC) board as well.
I recommend having a service technician come out and diagnose which part failed and repair your range.
Posted on Dec 18, 2008
shinn8
  • 85 Answers
SOURCE: What does F-1 mean on the electronic display of stove?
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
Posted on May 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: My gas range KGSC308 timer shows F2:E1. I cannot
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!##
Posted on Oct 01, 2010
  • 61 Answers
SOURCE: Kenmore gas range beeps and displays code E1-F2
I'm not sure if the error codes are the same for gas ranges as they are for electric, but this is the solution for that same error code with the electric version. you might give it a try with yours and see if it works the same for gas as well (I would assume the electronics are similar between the two).
you probably don't need to replace any parts to solve this problem. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem might vanish. if the error code returns, try pulling out the connector, cleaning the contacts with a pencil eraser, reinserting it into the slot and repeat above with the paper.
the paper trick worked for me for about two weeks, then the problem happened again. the next fix I tried was to unplug the keytail (the ribbon connector) from the slot on the control panel. there is a clip in each side of the black plastic receptacle (the place where the keytail plugs in on the electronics control board). pres them inward to separate the top portion of the receptacle, which I think helps to clamp the keytail into the bottom portion. the top and bottom fit tightly together, so you might need to use a small screwdriver at the joint to pry them apart, however, I did not find it necessary to remove that clamp in order to remove or replace the keytail on mine.
smoke and other sticky cooking fumes cling to the contact wires on the keytail and the pins in the receptacle (as well as other surfaces) and that buildup interferes with the electrical connection they need to make. once the keytail is free, clean it well with a mild cleanser (I used a slightly soapy, damp dish sponge) and dry it with a clean paper towel. FYI, one side of the keytail has the exposed wires which make contact with pins in the receptacle on the control board. the exposed side is on the inside surface of the curled keytail ribbon, the outside surface is translucent plastic insulation (you can feel that the outside is smoother than the inside because the inside has the contact wires exposed). the inside is the side you want to make sure is clean because those are the wires that need to make electrical contact with the pins in the receptacle.
next, use sharp scissors to carefully trim a small uniform strip (roughly 1/16 of an inch or less) off the end of the keytail. then plug it in again (remembering to use the top portion of the receptacle to secure it in if you had removed it). doing this provides a fresh spot on the exposed wires to make contact with the pins in the receptacle. my theory is that over time the wires wear out at the points where they make contact with the pins. trimming the edge allows you to insert the keytail deeper into the receptacle and therefore, the pins will contact the wires in the keytail at a new, unworn spot. it's been over a week now and so far, it seems to have fixed the problem on my stove. if I get the error message again in the future, my next step will be to try paper trick again (at least as a temporary solution), but I doubt it will be necessary any time soon.
be sure to try all other solutions first before ordering any parts. I first changed the control board for $125 and there was no change. then I ordered the touchpad, but ended up fixing the problem before it arrived. I sent the touchpad part back to Sears Parts Direct after I figured out I didn't need it and they eventually refunded $15 less than I'd paid. of that difference, $13 and change was for shipping, so the other dollar plus must have been a miscalculation or a restocking charge or something, but I didn't bother following up to find out. I also had to pay about $3 to ship it back to them via USPS because I didn't hear the UPS guy when he dropped it off on the doorstep, so I wasn't able to simply refuse the delivery.
good luck with your repair.
Posted on Nov 18, 2010
On the oven display it shows f2 i need to change the sensor probably it overheated please tell me where i fid this part in my oven i have a hotpoint rgb745bea8wh it is 8 years old now
Hi yitz321,
The F2 error often occurs when the control senses oven temperature above 615F - 630F. The easiest way to correct this is by looking for a welded relay contact on bake or broil relays. If it has a welded relay contact, please replace the oven control. The oven control is the one who measures resistance of sensor circuit, not an actual oven temperature.
Hope it helps.
Thank you for using FixYa.
May 13, 2011 | Hotpoint RGB745 Gas Kitchen Range
My range displays eo -f2- what does it mean
Means you have a bad control, you can purchase the part and watch a video that explains how to make this repair at the link below,
http://www.appliancerepairlesson.com/
Mar 08, 2011 | Whirlpool GS465LELS Dual Fuel (Electric...
Oven says F2
F2 code means.
Oven too hot Replace relay board (if present) or oven temperature sensor Good Luck
Nov 27, 2010 | Hotpoint RGB745 Gas Kitchen Range
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
May 20, 2009 | Hotpoint RGB745 Gas Kitchen Range
Get a f2 code after oven has been on for a few minutes
Hi
The error code F2 means high resistance or interference in oven temperature sensor, you need to replace the sensor.
Please revert for further assistance and Do rate the solution as FixYa if found useful.
Thanks
Rylee
Mar 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
When we cook in the oven it says F2 every 10 mins.
This means that your oven temp sensor has failed. There is no way to fix the sensor. You have to replace. The f2 means that your oven has reached its heaeting limit and it shuts down for safety. Replace oven temp sensor and it wil fix it.
Nov 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Flashing F2 while the oven is on
f2 is a faulty oven temp sensor. need to replace the sensor. located in the oven cavity 2 screws hoding in protrudes 3-5 inches out thin metal cylinder
Mar 16, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
359 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
