Question about ASK Proxima C160 Multimedia Projector
Replaced bulb for a proxima c160 bulb won't strike led power button flashes red what can I do
    Scholar:
  • 34 Answers
You may have purchased an aftermarket generic lamp. The chances that the lamp is defect is about 20% with the counterfeit products....Read here for a better explanation:
http://www.fixyourdlp.com/guides/ask-proxima/sp-lamp-017/ask-proxima-sp-lamp-017-lamp-replacement-guide.php
I also suggest buying the original lamp as recommended by the above link. You may find yourself troubleshooting further for no reason simply by buying an aftermarket replacement.
Posted on Oct 18, 2011
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
I have a ask proxima c160. i have a power led light when i plug it in.when i turn it on it turns on then right back off. What might this be? basic trouble shooting. before i tear into it. thanks
I'm not where I can consult my tech notes but you can try resetting the lamp hours and the dust filter hours and can also check your lamp by removing it and looking straight into it to see if any visible cracks or bubbles are in the reflector. That would indicate a bad lamp. Oh yeah-- make sure the grill covering the dust filter is seated properly and there is a little "eye" sensor that detects whether the grill is present so make sure it is clean or it could send false signals.
Sep 28, 2010 | ASK Proxima C160 Multimedia Projector
How to change proxima c160 lamp
On manual below on page 38 tells you how to replace the lamp.
proxima-c160-manual.pdf">http://www.aboutprojectors.com/pdf/ask-proxima-c160-manual.pdf
Good luck and please rate 4 thumbs for the free answer
Mar 23, 2010 | Office Equipment & Supplies
My projector keeps shutting down(sleep mode) after only being on for 5 minutes. how can I stop that from happening?
The problem with you Projector is most likely the bulb. Here is a good guide on how to change out the lamp on your projector:
I also suggest reading about the counterfeit lamps and buying the original lamp as recommended by the above link. You may find yourself troubleshooting further for no reason simply by buying an aftermarket replacement.
Mar 04, 2010 | ASK Proxima C160 Multimedia Projector
How to tell if lamp is dead? Lamp strikes 5, Red LED flashes once over and over. All whirs and whines as normal. Removed bulb housing, one side half-caked with dust, vacuumed it. Removed bulb, looks fine...
the lamp needs replacement.as per the manual.
the light flashes 5 times.this is the indication to replace lamp.
replacing the lamp should solve the lamp.
Lamp strikes 5, Red LED flashes once over and over the solution is lamp replacement.
for getting lamp you can get it from
www.partstore.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
No power
if there anre no leds lit on the top, the power supply needs to be replaced.
Jan 19, 2010 | ASK Proxima C160 Multimedia Projector
How to connect my C160 ask proxima to my laptop hp?
C160 has M1-DA connector. You need an adapter.
Try this or Google it.
Dec 06, 2009 | ASK Proxima C160 Multimedia Projector
My Ask Proxima won't turn on
if there is no amber led, the power supply is bad. if you have an amber led and the button won't work, there is an obstruction under the button panel. if the led is red and no fans come on, the fans or the power supply is bad. if the fans come on but no light, the colorwheel is bad.
Nov 03, 2009 | ASK Proxima M2+ Multimedia Projector
Lamp won't strike
the ballast might be bad as well.
Aug 07, 2009 | ASK Proxima C160 Multimedia Projector
ASK Proxima C160 Multimedia Projector Logo
242 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
