Hi i have just purchased a adsl modem with router model f5d7632-4 and when i run the set up disc it will not conect to the internet at stage 6 i have checked all conections and details of my sever and these are right when i disconect your modem and re conect my speedtouch modem i can conect to the internet my server is virgin is there a problem with this server?
  • metaledy Mar 24, 2008
    this is a new modem ad filters are fitted on all locations
    all green lights come on .i can't connect the modem as they are all in one
    Genius:
  • 3,587 Answers
Is this adsl modem new to your location? Did you put the filters on all the other phone devices, including fax machines first?
Posted on Mar 24, 2008
  • Patrick Michaels
    Patrick Michaels Mar 24, 2008
    server is probably fine..
  • Patrick Michaels
    ok..good..so, are you getting all green lights showing connections, including the signal from phone line? can you connect the modem to your computer, without router, to isolate that as a possible cause?
SOURCE:
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
Belkin ADSL modem F5D5630au4 keeps losing conection
are you running filesharing? sometimes too many connections at once will cause the modem/router to crash and reboot
Oct 18, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Zoom router
Have you tried configuring the ADSL modem router for the internet connection?
Its possible that since you have changed the ADSL modem router, you may have to configure the ADSL modem router for it to work fine. The configuration depends on what Internet provider you have but you may try these steps for now:
1. Make sure the connections are correct. Connect the computer to the LAN port and the ADSL line to the port assigned for that behind the device.
2. Launch an Internet browser and access http://10.0.0.2 and press enter. If a dialog box appears, set the user name as admin and password as zoomadsl and press enter.
3. On the basic setup page of the ADSL router, set the appropriate encapsulation and other settings based on the settings of your provider. If you do not know the settings for your provider, there is a table specified on the user guide for the ADSL router. Here is the link: http://zoom.com/documentation/adsl/5590_UserGuide_EngD.pdf
Jul 19, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Need Zoom X6 help unresponsive
make sure your ethernet port is set to 'obtain address' and 'DNS' automatically (IE use DCHP and not static IP address) The software should be able to 'find' the zoom modem then.
Jan 22, 2008 | Zoom X6 Adsl Modem/router Rohs...
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Belkin mimo installation
what you should have purchased was a modem/router and not a seperate router to connect to your modem, but the modem should connect to the cable/adsl port (wan) using the initial RJ45 lan cable, and then a lan cable from one of the 4 ports on the rear to each pc.
Sep 24, 2007 | Belkin (F5D5231V4-SN-PD) Router...
Open Questions:
MCAFEE TecH sUppoRt phoNe +18OO8*O31++O69 number Usa.G.Ds Usa MCAFEE USA phone number is ranked #2 out of 2 because 7,728 MCAFEE USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he MCAFEE USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, MCAFEE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. MCAFEE USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact MCAFEE USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling MCAFEE USA Calling MCAFEE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from MCAFEE USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with MCAFEE USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare MCAFEE USA's phone numbers against each other. Contacting MCAFEE USA in General While I8OO8O31O69 is MCAFEE USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach MCAFEE USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact MCAFEE USA.
Oct 21, 2019 | Mcafee Computers & Internet
Computers & Internet Logo
90 people viewed this question
Ekse
Marvin
Marvin
