Question about Toshiba Satellite M45-S265 Notebook
I want to upgrade my Hard Drive but I don't know what kind to buy is their a specific kind does it have to have the same RPM. I think its a ATA/100. thank you.
    Problem Solver:
  • 6 Answers
2 important things
1 the rpm should not be faster than the original hard drive and 2 you need to update the DMI afterwards so you can reinstall the OS
Posted on Apr 27, 2010
Screen flashing occasionlly!
Is your screen flickering, or are you referring to some kind of error message flashing up on the screen? I'm curious as to why you think this is due to your hard drive. Please advise.
Oct 17, 2013 | Toshiba Genuine MK2004GAL 20 GB 4200 RPM...
After formatting my PC then also showing the hard disk failure error and telling to backup all programs. so what to do?
Buy a new hard drive, and start over.
www.newegg.com You want a 3.5 ATA (not SATA) hard drive somewhere around 500 GB 7200 RPM not 5400 RPM. Something like: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136109
Jun 10, 2011 | Seagate Barracuda 7200.10 320 GB ATA-100...
I want to upgrade my Hard Drive need help
You may want to stick with the same manufacturer as the drive you now have.
The Toshiba site lists the drive as ATA.
The RPM speed should not matter as long as it is 5400 or higher.
You can get some good deals from reputable on-line stores
Apr 26, 2010 | Toshiba Satellite M45-S265 Notebook
I need to know what kind of hard drives and other hardware i can use with a HP Compaq D530 Socket 478
HERE shows an overview of the specs for the HP d530 series. Shows IDE type HD's.
Technical Specifications - Hard Drives
7200 rpm SMART III Ultra ATA/100 Hard Drives 40-GB Capacity 40,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 78,165,360 Operating Temperature 41° to 131° F (5° to 55° C) 80-GB Capacity 80,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 156,301,488 Operating Temperature 41° to 131° F (5° to 55° C) 160-GB Capacity 160,000 MB Rotational Speed 7200 RPM Interface Ultra ATA/100 Height 1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including setting) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 320,173,056 Operating Temperature 41° to 131° F (5° to 55°C)
Feb 21, 2010 | Computers & Internet
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
I need to replace the hard drive in my v5000 Compaq laptop. it is currently a mk8025gas toshiba 80gb. how do i choose a newer updated hard drive to match? do i just install and turn back on with the xp...
Basically you insert a new drive and insert the Windows XP installation CD and follow the screen instructions.
The specification for hard drives for the Compaq V5000 are as follows :-
Table 6-3
Hard Drives
120-GB* 100-GB* 80-GB*
Dimensions
Height
Width
Weight
9.5 mm
70 mm
102 g
9.5 mm
70 mm
102 g
9.5 mm
70 mm
99 g
Interface type ATA-5 ATA-5 ATA-5
Transfer rate
Synchronous (maximum)
Security
100 MB/sec
ATA security
100 MB/sec
ATA security
100 MB/sec
ATA security
Sep 30, 2009 | Compaq Presario 1.8GHz Mobile AMD SempronT...
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
I need to replace the dead hard drive in my dell dimension 4500s. Current dead drive is a 40GB Ultra ATA-100 (7200 RPM). Can someone tell me what I can upgrade to. I think I have the flat data cable so it...
You can replace the hard drive with a larger capacity hard drive. Best bet would be a 250GB .
Hard drive have come down in prices, you should be able to get a 250 GB. for less then $100.
Western Digital ansd Seagate are my preference.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Dell Dimension 4500 PC Desktop
Hard drive replacement
I'll put it like this; The fact that it's and Ultra ATA 100 interface and that it's a 5400 RPM drive is somwhat of a concern.. Don't know if your laptop will support the 5400 RPM speed, but the good news is,it won't hurt your laptop to try it.
Also, I don't think the Ultra ATA 100 interface will be a problem, maybe require you to change BIOS setting (maybe).
Jan 14, 2009 | Seagate Notebook Hard Drives: 40GB...
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
