Question about Saeco Classico Espresso Machine
Water does not heat
Saeco Classico. Water is not heating. Pump works but water coming out remains cold.
    Problem Solver:
  • 11 Answers
Equally likely to be the 95 Deg thermostat has failed.
Posted on Nov 21, 2010
  • Peter Engel Nov 23, 2010
    If the thermostat failed wouldn't the water still heat up but not stop heating at the 95 degree thermostat threshold?
  • Graeme Scott Nov 24, 2010
    I just fixed mine and it was the 124 deg thermostat.
    It is a Normally Closed thermostat so if it fails, it fails open and the boiler gets no power. Simple way to test is to see if there is continuity across the thermostat when the machine is cold, if there's no continuity, the thermostat has failed.
More then likely it's the boiler.
Posted on Apr 27, 2010
  • Graeme Scott Nov 21, 2010
My Saeco Classico has problem. The pump is working
It sound as though the boiler is blocked by scale. May also be the coffee filter that's blocked. I am not familiar with this machine, but assuming that it's just a manual espresso machine, try running it with the filter handle removed. Any water emerging? If so, the coffee filter cup and/or filter handle outlets may be blocked. If there is only a small flow the boiler is almost certainly blocked with scale and descaling may cure the problem (do the first run with the filter handle off the machine. Next run with it on)
Oct 22, 2013 | Saeco Classico Espresso Machine
Machine is not making coffee
We need some information to be able to help can you describe what is does and what not, do you have water without coffee in it, does it turn on at all, does it heat up, do you get hot water or steam
Feb 21, 2012 | Saeco Classico Espresso Machine
Connect Saeco Incanto Classico machine directly to water source
In our shop we come off the treated water supply with a water pressure regulator (adjusted to a very low pressure)and use a barbed fitting to connect to the hose inside the machine. You should be able to do something similar by removing the water tank seat on the body of the machibne and using the existing hole to connect your water. If you need something more specific contact purpleturtlecoffee@yahoo.com
Jun 01, 2009 | Saeco Incanto Classic Espresso Machine
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
No Water Flow/No Water Draw
Sorry for not responding to you request, but I was not receiving any emails from Fixya.
You can contact me directly if you still need help with your espresso machine.
johnny@CeriniCoffee.com
Authorized Saeco Service Center
www.CeriniCoffee.com
Oct 26, 2008 | Saeco Classico Espresso Machine
V entilate?
the machine come with a little pump put water in the pump and insert the pump inthe water hole and press the water in the machine try to ventilate fill the water tank cheers
Jan 16, 2008 | Saeco Classico Espresso Machine
Water Too Hot, Coffee Too Watery
Sounds like there is something wrong with the machine. Could be the thermostats or maybe something like an internal leak that is causing the machine to overheat. It sounds to me like you need someone to take a look at it..
We service saeco espresso machine and are stationed out of New York..
If you need parts of cleaning supplies check out our website:
Jan 01, 2008 | Saeco Classico Espresso Machine
Steam jet in Saeco Classico
Try Descaling your machine. A lot of times calcium will form on the inside of the boilers and on the heating elements in espresso machines causing heat transfer issue and clogged lines.
If the heating element cannot transfer enough heat fast enough then your steam will run out.
If you need a good descaler or descaling instruction visit www.CeriniCoffee.com
Dec 22, 2007 | Saeco Classico Espresso Machine
Saeco Classico Espresso Machine Logo
115 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
