Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Cant turn it off, it seems to be locked? - KitchenAid Architect Series KEBC107KSS Electric Single Oven
  • KitchenAid Master
  • 3,051 Answers
HELLO THERE
On some of these ovens they have a internal reset device that needs to be reset and this is done by unplugging the oven and waiting for one hour then plugging it back in and waiting for 5 min befor you attempt to unlock it.
Now on some of the newer model ovens all you have to do is unplug wait 15 sec and plug it back in for 5 sec then repeat this step 3 times ok so please try these and let me know how this goes
Best regards Michael
Posted on Apr 27, 2010
No power on stove after using self clean oven door is locked and cant be open is there a braker swith somewhere
A self cleaning oven that won't open after the self cleaning cycle is usually the oven has not had time to cool down from the high temperatures of cleaning. You should wait at least an hour to open it. You can also try to unplug the unit or turn of the breaker to the over for at least five minutes. You will then have to reset the clock and then try to move the door lock. If that does not work, you can set the self clean cycle again for but only allow it to work for 15 minutes, then cancel the cycle and let the oven cool and then again try to move the door lock or open the door If that does not work, then the lock will have to be accessed and moved manually to open the door
Some ovens need the door to be manually unlatched before the controls are set to the off position before they can be unlocked.
Mar 07, 2011 | KitchenAid Ovens
I ran the self cleaning oven and now it is locked and I cant turn it on?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 20, 2011 | Magic Chef Ovens
The display shows LOC - but the door is open - cant turn on the oven
Hello & Welcome to FixYa
After reading your question the problem seems to be with the control which got locked. To unlock the controls press and hold the STOP/OVEN LOCK button for 20 seconds. If the problem returns then check the door and make sure it is fine, after this you can unplug the unit for 15 minutes and then try to reset it again. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
End of the self cleaning cycle, lower oven door stays locked
the heat seems to have seized the lock. if you can tap at it with a screwdriver and hammer, the vibration may knock it loose. you can also spray it with liquid wrench or wd-40 first
Jun 21, 2009 | Electrolux ICON Designer E30SO75ESS Oven
Kenmore oven 41775790 locked door
after self cleaning with the racks still in oven, i cannot get the oven door open, locked down, does this have something to do with the racks left in oven during cleaning. what do i need to do
Jan 17, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
How do I switch off child lock from my neff oven 1641
So, you should have a "-s-" being displayed if you have the child lock on.
The switch for selecting the oven mode( oven, fan oven, grill etc)
-from its off position, turn it one click left so the light comes on, and then click it back to off. Do this three times in quick succession. The "-s-" should now have disappeared and you can use your oven again.
Regards,
Steve.
Sep 09, 2008 | Neff B1641 Single circotherm super...
Smeg se375mfx5 / stainless steel
i suspect you took the door off without locking the hinges
you will have to put the hinges in the lock position before putting back.
lay door on a blanket with hinges upwards. force the hinges back and bring the locking arm up to lock the hinges.
this requires considerable strength
Jul 05, 2008 | Smeg SE399X/5 Stainless Steel Electric...
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
